Any help is appreciated!
Old Nov 11, 2006 | 04:12 PM
ari.'s Avatar
Default Any help is appreciated!
Heres the deal ,
My 2g Teg , is an auto , last week , changed oil and what not , so im lookin under the car and happened to notice that the tranny cooler line or what ever it is appears to be leaking.
So i put a quart of approved trans fluid in there and everything seemed fine . The next day i leave my house , everything was normal , then get maybe a 1/4 mile down the road and and make a right hand turn , then realize i left my ID at the house.
So i pull into a driveway to turn around. I put the car into reverse , and it makes a horrible grinding noise , so i put it back into drive to pull foward a bit more , away from the street.
So as i pull foward , it made more grinding noise , so im like WTF , and looked at my gauge cluster and noticed that my rpm's are climbing as i tap the throttle to pull up more.
So it's make more weird noises , i'm looking at the guages again and see that my speedo is climbing up , pretty quickly , so i freak out and throw it in Neutral , and turn it off.
I get out to look for a puddle of trans fluid but see nothing under the car , or in the street from where i just came from.
15 minutes later my step-dad pulls the car back home , so it sat all of this past week untouched . So im at home today bored outta my mind , so i figure what the hell, goto the store grab a quart of trans fluid.
Get back to the house put it in , let the car idle for 20 mins or so , checked under the car here and there looking for leaks but see nothing.
So i put the car into reverse and it goes into gear , so i witch back in forth between reverse and drive and everything is working fine.
So i back out for a test drive , i get about 20-30 feet and the speedo starts climbing again , so i stop and as i goto put it in park , the speedo was steady at about 20mph , and when i put it into park , it makes the griding sound again.
So basicly im not sure if the trans is completely shot , i did notice the "cable" that runs from my tranny to the inside of the car looked a bit outta place and a friend mentioned it's possible my tourque converter maybe came outta place , wich im not sure about.
So if you guys could suggest anything to check , or go by some kinda procedure i would really appreciate it , and if you have any answers i'll be here all nite lol the little guy is down for the count so thanks in advance!!
Old Nov 11, 2006 | 07:50 PM
ari.'s Avatar
Default Re: Any help is appreciated! (skinnyshugg [V2])
ttt
Old Nov 11, 2006 | 10:22 PM
ari.'s Avatar
bumpski
Old Nov 12, 2006 | 05:30 PM
ari.'s Avatar
Default Re: Any help is appreciated! (moops vs moors)
Thx for the help advice buddy , apparently drive side axle wasn't locked in , but i got it back to norm , thanks again!
Old Nov 12, 2006 | 06:34 PM
93lsd's Avatar
yea u just might wanna re grease the bearings insted of buying a new one
Old Nov 12, 2006 | 06:56 PM
ari.'s Avatar
Default Re: (93lsd)
the clip is bad on it , im gonna yank it and pick up another , one i guess
Old Nov 12, 2006 | 06:59 PM
93lsd's Avatar
what clip
Old Nov 12, 2006 | 07:19 PM
ari.'s Avatar
Default Re: (93lsd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93lsd &raquo;</TD></TR><TR><TD CLASS="quote">what clip </TD></TR></TABLE>
the small clip on the end of the axle that goes into the trans
Missing_In_Action
Apr 5, 2008 03:19 PM
JDMSalvi55
Honda Civic (2001 - 2005)
Dec 18, 2007 12:03 AM
ari.
Nov 12, 2006 05:29 PM
KaoSyN
May 17, 2005 11:21 PM
civilEX98
Jan 23, 2005 09:15 AM
