hondata reflash
Old Nov 11, 2006 | 04:12 PM
luckyrsx's Avatar
Default hondata reflash
im thinking of doing a reflash on my rsx. was wondering if anyone has dones this to there car. does anyone have suggestions or what they thought of the reflash. any input is good
Old Nov 11, 2006 | 04:53 PM
jdmpwr07's Avatar
Default Re: hondata reflash (luckyrsx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luckyrsx &raquo;</TD></TR><TR><TD CLASS="quote">im thinking of doing a reflash on my rsx. was wondering if anyone has dones this to there car. does anyone have suggestions or what they thought of the reflash. any input is good</TD></TR></TABLE>
ive heard good things about the reflash. it gives good power all throughout the powerband and raises the rev limit. if you really want a good tune though go for k-pro
Old Nov 12, 2006 | 12:32 PM
rs_sexy's Avatar
Default Re: hondata reflash (sleepin02rsx)
is there a k-pro for an automatic rsx???
Old Nov 12, 2006 | 03:14 PM
cnyej1's Avatar
Default Re: hondata reflash (rs_sexy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rs_sexy &raquo;</TD></TR><TR><TD CLASS="quote">is there a k-pro for an automatic rsx??? </TD></TR></TABLE>
Hondata doesnt do Kpro on Automatic ECU's, but they do a re-flash for the autos.
Old Nov 12, 2006 | 05:50 PM
rsxtacyy's Avatar
I've got the reflash but i kept the rev limiter at 8100 it runs real nice and has a more torquey feel but i wish i would have spent the extra 400 and got the K-pro. I-Vtec wont kick in when the car is cold you have to run it for a while. Overall I am happy with the reflash
Old Nov 12, 2006 | 06:13 PM
hondafrk505's Avatar
Default Re: hondata reflash (acurtayy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acurtayy &raquo;</TD></TR><TR><TD CLASS="quote">I've got the reflash but i kept the rev limiter at 8100 it runs real nice and has a more torquey feel but i wish i would have spent the extra 400 and got the K-pro. I-Vtec wont kick in when the car is cold you have to run it for a while. Overall I am happy with the reflash </TD></TR></TABLE>
theres a reason why vtec wont kick in when its cold..
Old Nov 12, 2006 | 06:28 PM
cnyej1's Avatar
I believe it wont engage when its cold either with or without Kpro.
Old Nov 12, 2006 | 08:24 PM
PrecisionH23a's Avatar
The reflash is pretty good. Here is a bone stock k20a2.
http://hondata.com/reflash_rsx.html
Old Nov 12, 2006 | 09:23 PM
CivicDude2k4's Avatar
ok so the whole "VTEC doesn't kick in when it cold" thing is something new to me, i have never heard that before. someone care to explain that a little bit?
Old Nov 12, 2006 | 09:27 PM
cnyej1's Avatar
Default Re: hondata reflash (CivicDude2k4)
Vtec does not properly engage until the motor is up to operating temp.
Old Nov 12, 2006 | 09:31 PM
Default Re: hondata reflash (cnyej1)
well you learn something new everyday. thanks
Old Nov 12, 2006 | 09:37 PM
cnyej1's Avatar
Old Nov 12, 2006 | 10:28 PM
dc5tegk20's Avatar
would you sujest leaving the rev limit down? it scares me going above my factory limiter i dont want to expletive up my 06' engine with 10,000 on it.
any CEL after the relfash and how long would you say from step one of taking the ecu out to turning the car on
Old Nov 12, 2006 | 10:29 PM
dc5tegk20's Avatar
correct me if im wrong but doesnt vtec alsohave somthing to do with oil pressure? hence contributing to the cold motor factor
Old Nov 12, 2006 | 11:18 PM
a2_DC5's Avatar
Default Re: (dc5tegk20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5tegk20 &raquo;</TD></TR><TR><TD CLASS="quote">correct me if im wrong but doesnt vtec alsohave somthing to do with oil pressure? hence contributing to the cold motor factor</TD></TR></TABLE>
something? it has everything to do with oiL pressure...hence the separate oiL pressure switch that monitors the iV-TEC system
Old Nov 13, 2006 | 07:09 AM
Default Re: (a2_DC5)
8000 is as high as you want to rev on a bone-stock K. After 8000, you will run into valve-train related problems.
Old Nov 13, 2006 | 10:06 AM
ebp_dc2's Avatar
Default Re: (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">8000 is as high as you want to rev on a bone-stock K. After 8000, you will run into valve-train related problems.</TD></TR></TABLE>
very untrue. k20a2 (as long as ur not one of the first 20,000 created) and k20z's have the same valve springs and retainers and the type r model, which redlines at 8600 RPM. Hondata finds no problem revving these motors to 8600 safely. I wouldn't do it every time you shift, but it is definitely safe in moderation.
Old Nov 13, 2006 | 10:15 AM
rsxtacyy's Avatar
It depends on what you want out of the reflash. If you have a heavy foot and will be tempted to rev it out all the time, I wouldn't suggest it. If you are planning on other engine and valvetrain mods then I would go for it. 8100 with the reflash works out plenty well for me right now.
Old Nov 13, 2006 | 10:50 AM
Default Re: (ebp_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebp_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
very untrue. k20a2 (as long as ur not one of the first 20,000 created) and k20z's have the same valve springs and retainers and the type r model, which redlines at 8600 RPM. Hondata finds no problem revving these motors to 8600 safely. I wouldn't do it every time you shift, but it is definitely safe in moderation. </TD></TR></TABLE>
That's funny... because I had a detailed discussion about this with Doug when I was at Hondata last year and he told me specifically that after about 8000rpms that you can start to experience valve-float and possibly bent valves. Doug mentioned that they have gone higher like you have mentioned, but they have ran into problems as he told me a year ago. But again, if you aren't making power past 8000rpms then why rev it any higher?
I checked into further detail on the Hondata website and here is some further info:
"Rev limits and Valve springs
Based on information from TODA Japan, the Type-S and Type-R have the same exhaust valve springs. However the intake side uses F20C (S2000) intake springs for the outer spring and a Type-R for the inner spring. TODA also mentioned that Honda is now using single springs of a higher class material for the newer Type-R's.
The interpretation here is that the stock valves are good. We have had a test vehicle (K20A2 in a Civic Si) running with an 8900 Rev limit for 2 months now. In this car you change gear when the Rev counter points to 20 mph!
Any increase in RPM limit though is at your own risk. If you suffer engine damage that is related to excessive revs Honda/Acura will not cover your warranty. If this of a concern, upgrade your valve train or use a program with a stock rev limit.
I'm going to contact Doug and talk to him a little more about this.
Old Nov 13, 2006 | 11:10 AM
dc5tegk20's Avatar
i think ill stick with my 8100 rev limit
Old Nov 13, 2006 | 11:49 AM
dc5Aspec'd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5tegk20 &raquo;</TD></TR><TR><TD CLASS="quote">i think ill stick with my 8100 rev limit </TD></TR></TABLE>
yeah I'll have to agree, i already have a problem with jumping all over that 8100rpm, giving me 8600rpm's would just turn into a disaster.
Old Nov 13, 2006 | 03:29 PM
dc5tegk20's Avatar
Default Re: (dc5Aspec'd)
how true justin hahaha , its so hard to drive our damn cars normal lol thats all we need is another 5 grant to play with lol
Old Nov 14, 2006 | 10:38 AM
D-Rob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5Aspec’d &raquo;</TD></TR><TR><TD CLASS="quote">
yeah I'll have to agree, i already have a problem with jumping all over that 8100rpm, giving me 8600rpm's would just turn into a disaster. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5tegk20 &raquo;</TD></TR><TR><TD CLASS="quote">how true justin hahaha , its so hard to drive our damn cars normal lol thats all we need is another 5 grant to play with lol </TD></TR></TABLE>
Your 15-second cars?
What's wrong with taking the K20 to 8600 RPM? If Hondata raises the rev limit, why ask differently?
I highly doubt 500 RPM is going to make a significant difference.
Old Nov 14, 2006 | 11:27 AM
dc5tegk20's Avatar
dammit d-rob go back to your lsvtec forums hahahaha no seriously you know i always love your input
IBriaIN
Mar 2, 2006 11:29 AM
IcebergMan
37
Oct 25, 2005 06:40 AM
HONDAzZz
16
Jan 27, 2004 06:22 AM
allmtrSI
10
Aug 18, 2003 06:33 PM
