DA water temp gauge problems..
Old Nov 11, 2006 | 12:52 PM
crxsir07's Avatar
Default DA water temp gauge problems..
Ever since i've owned my DA the temp gauge
always fluctuates, more than it should, never hot
always cold, my ECU threw a code for the ECT sensor
so i changed it, and no luck...it's actually worse, the
needle hardly moves, WTF!? am i going to have to
change the gauge in the cluster?
If i can't figure it out i'm just going to buy a Mechanical
temp gauge, thanks guys
Old Nov 11, 2006 | 02:09 PM
POE's Avatar
POE
try puttin a new thermo stat in the car.. cost like 15 bucks or so..
Old Nov 12, 2006 | 08:32 AM
crxsir07's Avatar
Default Re: DA water temp gauge problems.. (crxsir07)
thanks!, what's the sensor right on the T-stat housing, would that sensor cause the gauge to malfunction, it looks like the same type of sensor as the ECT in the head, i'll get a t-stat, and a water pump, while i'm at it, my T belt needs to be changed so i might as well do everthing
Old Nov 12, 2006 | 10:09 AM
Sam92Teg's Avatar
The connector right on your thermostat housing is the Engine Coolant Temp Switch that operates the radiator fan. I agree that you should swap your thermostat.
Old Nov 12, 2006 | 04:05 PM
crxsir07's Avatar
Default Re: DA water temp gauge problems.. (Sam92Teg)
i thought the ECT sensor was on the head, and the big two prong sensor on the back of the block (with the black rubber cover), i am deffinatly changing the t stat, and water pump, and my t belt, thanks for the help guys
wseg
Nov 7, 2015 08:27 AM
stocker2shocker91
Mar 24, 2008 01:19 PM
qwikz
Mar 2, 2006 07:26 PM
TypeR15
Feb 24, 2004 12:29 PM
