holdong fuel pressure
Old Nov 11, 2006 | 12:32 PM
bigislandc2's Avatar
Default holdong fuel pressure
i tried to search but nothing came up. i just had a question how do you fix a car that doesnt hold pressure. is it the fuel pump? i have already changed the fuel filter and the inj. what else needs to be done
Old Nov 12, 2006 | 06:42 AM
pyitrboy's Avatar
Default Re: holdong fuel pressure (bigislandc2)
How do you know your pressure is too low? What kind of pressure are you getting? With a fuel pressure guage connected, and the vacuum hose disconnected from the regulator, you should have 47-54 psi according to genuine acura manual. Reconnected you should haave 38-46 psi assuming you have a b18c1,bi8c5....b18b1 have slightly lower pressures. Most likely sounds like the regulator giving you the problem if pressure did not go down after putting back on the vacuum hose.
rdssk8rcs1
Oct 2, 2010 07:41 AM
Shogun_HCI
Jul 31, 2005 02:33 PM
Muckman
Dec 6, 2003 01:40 PM
ProjectCRXtacy
Jul 15, 2003 03:20 PM
iwouldHITit
Mar 8, 2003 09:52 PM
