2-b18 blocks, 2-b16 blocks 2 LS oil pans
Here are some extra blocks was going to do other projects but like most of us no time...All block sold AS is no warrantees
I have a LS block that is sleeve84mm but did leak out of the bottom, I’ve heard there could be a fix by some type of deffcon stuff but not sure it has 40 miles.. This block will need a slight hone for cleaning and a polished on the crank.. If you’d like this block can be resleeved through GE(golden eagle.) They can resleeve a block that has this type of sleeve...I called them.. I’m selling this one for a lil more due to the sleeve’s but not nearly what it cost me
$300 OBO) comes with rear main seal, crank,oil pump...
The other LS block has a bad rod journal and needs to be hit up a lil.. The cylinders a light hone would suffice. Comes with rear main, oil pump and crank$150
I have two more blocks stock b16's $150 each a 2000 si and sir forgot the yr. I’d suggest a hone and clean up the crankssir has a spun rod bearing, and I believe the SI is has a nice crank..
feel free to hit me up..I’ve been hella busy so please be flexible, if we can work out something for meet it would be great..thanks for looking all OBO
LS oil pans one is tapped for oil drain back $45...other is not and comes with oil pick up...$55
LS cover $15(lower)
Modified by Redwidow at 4:19 PM 2/25/2007
LS cover $15(lower)
riceball777
Mar 7, 2010 03:26 PM
Redwidow
Feb 25, 2007 07:16 AM
