jdm itr injectors
Old Nov 11, 2006 | 06:59 AM
type B16's Avatar
Default jdm itr injectors
for a all motor build, when is it definitely necessary to change the stock jdm injectors to lets say 440s?
Old Nov 11, 2006 | 07:01 AM
tartje's Avatar
Default Re: jdm itr injectors (type B16)
i was under the impression 440's were only necessary for a boost build. 330's should be fine? someone correct me if i'm wrong...
Old Nov 11, 2006 | 07:43 AM
RTW DC2R's Avatar
440s are huge on an all motor setup unless you are pushing a lot of power. I was on 370s around 60% DC and was making around 210whp. go to the RC Engineering site and calculate the size injectors you think you will need for your setup.
Old Nov 11, 2006 | 08:14 AM
sleeprhatch's Avatar
Default Re: (RTW DC2R)
440 on an all motor set up are crazy unless the compression is through the roof. I would go smaller.
jc2801
28
Sep 27, 2013 04:06 AM
wushubrian
Mar 14, 2005 12:37 AM
KS-R
Aug 9, 2004 05:02 PM
a1320honda
Apr 13, 2004 09:25 AM
