Jdm type-r wheel weights
Old May 7, 2002 | 03:49 PM
shirlenco's Avatar
Default Jdm type-r wheel weights
I know this is probably a redundant topic but what are the wheel weights for the j-spec type-r wheels. thanx.
Old May 7, 2002 | 03:50 PM
JohnnyBoy's Avatar
Default Re: Jdm type-r wheel weights (rated type-r)
http://www.wheelweights.net/
Should do the trick....
Old May 7, 2002 | 03:57 PM
Big Phat R's Avatar
do you mean weight of the rims?
PB - who thought he was looking for some bling bling JDM wheel weight to balance the rim
Old May 7, 2002 | 04:03 PM
K:()!!y's Avatar
Default Re: Jdm type-r wheel weights (Phat Bastard)
i recall something along the lines of 16 lbs, i believe.
btw,
https://honda-tech.com/zerothread?id=177434
-k-b0t, who is looking to lighten the garage a lil'...
Old May 7, 2002 | 04:22 PM
sisteve's Avatar
New User
Default Re: Jdm type-r wheel weights (K:()!!y)
http://www.hondaswap.com/reference/i...hp?mode=wheels
Old May 7, 2002 | 05:28 PM
K:()!!y's Avatar
Default Re: Jdm type-r wheel weights (sisteve)
Acura Integra Type-R (JDM 4-bolt) 15 x 6 Cast 12.3
Acura Integra Type-R (JDM 4-bolt) 16 x 7 Cast 17
Acura Integra Type-R (US model) 15 x 6 Cast 15.6
that should be (JDM 5-bolt) on the second one, right?
-k-b0t, who is unaware of 4-lug 16s...
Old May 7, 2002 | 05:49 PM
Mike M's Avatar
Founding Member
Hi Kbot
16x7 5x114.3 50mm weighs in roughly 17.5lbs
Old May 8, 2002 | 05:42 PM
shirlenco's Avatar
Default Re: Jdm type-r wheel weights (Dredrick Tatum)
thanx yall
Old May 8, 2002 | 05:49 PM
GokuSSJ4's Avatar
15.6 on the us wheels at least i thought that there were a little lighter then that
typhoon
Dec 26, 2006 08:21 PM
TypeRKoncepts
Mar 28, 2006 12:35 PM
hawaiiangumbo
Sep 30, 2004 11:56 PM
Kengs
Jun 22, 2002 10:25 AM
