Hood Dampers, Hood Shocks for EF, and CRX
Old Nov 10, 2006 | 04:57 PM
CRXBart's Avatar
Default Hood Dampers, Hood Shocks for EF, and CRX
I saw a thread on here awhile back where people had done them. From what I understand there isn't an app for our chassis, but someone had adapted them. I'm interested in doing a setup myself, and I came across this on EBAY:
Click me!
Anybody used these?
Old Nov 10, 2006 | 05:21 PM
90JPRCRX's Avatar
Smells like Tuna
Default Re: Hood Dampers, Hood Shocks for EF, and CRX (CRXBart)
ive been looking for those thanks
crxwolf has the expensive tein ones which work also
all you have to do is drill the hole for the mounting plate that goes onto the hood. you can use a fender bolt hole for the otherside.
Old Nov 10, 2006 | 05:25 PM
CRXBart's Avatar
Default Re: Hood Dampers, Hood Shocks for EF, and CRX (90JPRCRX)
I wonder if used the EG kit? I would spend the cash if it was worth it.
Old Nov 10, 2006 | 05:26 PM
90JPRCRX's Avatar
Smells like Tuna
yea, they are the eg ones.
Old Nov 10, 2006 | 05:28 PM
CRX Toad's Avatar
Hood prop is less weight. I thought you were a weight ***** Bart and now you want to add hood shocks they are more weight. You aren't going to live this one down now. You want to put some neons on it too and maybe enter some car shows?
Old Nov 10, 2006 | 05:36 PM
CRXBart's Avatar
Default Re: Hood Dampers, Hood Shocks for EF, and CRX (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">Hood prop is less weight. I thought you were a weight ***** Bart and now you want to add hood shocks they are more weight. You aren't going to live this one down now. You want to put some neons on it too and maybe enter some car shows?</TD></TR></TABLE>
I just found out K series swapped cars have a 200lbs penalty, and my minimum weight for comp 4 is 2200lbs with a K. So a few grams ove the front tires can't hurt. My hood is kinda flimsy with the webbing removed, so it should help that.
Old Nov 10, 2006 | 09:19 PM
Chase's Avatar
Search for Ryans(rywire) old post, Tein EK ones fit.
Old Nov 10, 2006 | 09:54 PM
CRXBart's Avatar
Default Re: Hood Dampers, Hood Shocks for EF, and CRX (EF8kid)
Thanks Chase. I just found Ryan's thread and then I ordered the Tein EK units. Should be here some time next week.
Old Nov 11, 2006 | 08:56 AM
Fred n J_v2.0's Avatar
http://www.redlinetuning.com/Q....html
I have those on my EF. User "CWBETB" recommended them to me.
Old Nov 11, 2006 | 12:40 PM
SIred91's Avatar
Rainman
Took the words right out of my mouth Toad!! You cool mang.
Old Nov 11, 2006 | 01:30 PM
CRXBart's Avatar
Default Re: Hood Dampers, Hood Shocks for EF, and CRX (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">Took the words right out of my mouth Toad!! You cool mang.</TD></TR></TABLE>
My hood is pretty flimsy with the removed material to clear the motor. It sags a little with just the 1 prop rod. The 2 struts will hold it more securely, plus I will be able to remove more material from the hood, and possibly save more weight. I'm not doing this for typical ricer reasons. I'm actually going to paint the Tein green **** so it doesn't look tacky. I don't have hatch struts nor do I plan to reinstall them, but the hood needed something better. I never open my hatch so it ididn't matter.
Old Nov 11, 2006 | 01:34 PM
STREETWERKZ's Avatar
buy some slicks first.
i wanna see that ****** runnin 11s
Old Nov 11, 2006 | 01:49 PM
CRXBart's Avatar
Default Re: Hood Dampers, Hood Shocks for EF, and CRX (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">buy some slicks first.
i wanna see that ****** runnin 11s</TD></TR></TABLE>
Don't worry I've got allot of wheels, and tires to buy this winter, but there will be slicks. The winter to-do list.
88 Doors
HF Roof
8-point cage
Harnesses
Complete repaint
Tein Hood Dampers
Koni Race SPSS w/ Custom GC springs
4-15x7" Bronze TE-37's w/ Toya RA-1s
2-15x8" Bronze TE-37's w/ 24x9"M&H slicks
And possibly
Lexan windows
All that will be done before the next time it is drag raced.
Old Nov 11, 2006 | 02:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">
2-15x8" Bronze TE-37's w/ 24x9"M&H slicks </TD></TR></TABLE>
you might want to PM revoltallmotor (alex edge) i know he has some 13 inch bronze TE37s
Old Nov 11, 2006 | 02:33 PM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">you might want to PM revoltallmotor (alex edge) i know he has some 13 inch bronze TE37s </TD></TR></TABLE>
Thanks for the heads up but I can't fit 13" over my brakes.
Old Nov 11, 2006 | 02:57 PM
Tippyman's Avatar
I've seen them done on an EF. Looked real nice.
He's a real big EF guy on this site, but mainly hangs out in the A/C forum.
Old Nov 11, 2006 | 03:55 PM
1990crxsir's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">My hood is pretty flimsy with the removed material to clear the motor. It sags a little with just the 1 prop rod. The 2 struts will hold it more securely, plus I will be able to remove more material from the hood, and possibly save more weight. </TD></TR></TABLE>
Once you add them be careful when closeing you hood. A friend and I made a custom setup on his Mazda and he had removed some material from under his hood. He bent his hood closing it.
Old Nov 11, 2006 | 04:48 PM
Thanks for the heads up but I can't fit 13" over my brakes. </TD></TR></TABLE>
gotta take the good with the bad, i guess.
keep us updated. car came a long way. i for one never thought the K was gonna be in there.
sodaZC
11
May 14, 2014 10:45 AM
bmxtrev
Jan 28, 2012 10:34 PM
18gLUDE
Nov 21, 2007 09:44 AM
chunkybs
Jul 22, 2006 09:53 AM
eMpAtHy
Mar 9, 2005 03:12 PM
