Can I use regular heater hose on back of block?
Old Nov 10, 2006 | 03:12 PM
dinko's Avatar
Default Can I use regular heater hose on back of block?
hose #2 in the picture has a hole/crack in it and is leaking coolant very slowly. i just wanted to make sure i could use a regular piece of heater hose from an auto store instead of buying a $10 piece of hose from acura, wait for shipping and all.
thanks in advance.
Old Nov 10, 2006 | 03:14 PM
NJcoupe's Avatar
Default Re: Can I use regular heater hose on back of block? (dinko)
Its going to be hard to bend without being kinked.
Old Nov 10, 2006 | 03:20 PM
dinko's Avatar
Default Re: Can I use regular heater hose on back of block? (dxcoupe.)
well i just tried bending a piece of hose into same shape, roughly same diameter, and it didn't kink...pretty smooth actually.
i know lack of coolant will make it idle like donkey ****, but could this little hole in the coolant line cause my car to idle at like 2-3k? usually my car idles around 1k with the m22's, but it started idling like crap right around the time i realized i had a coolant leak.
Old Nov 10, 2006 | 04:27 PM
loudassVTEC's Avatar
You probably have some air bubbles in the lines because of the leak.
Old Nov 10, 2006 | 05:04 PM
qfast817's Avatar
Default Re: Can I use regular heater hose on back of block? (loudassVTEC)
i used a brass pipe u-bend and then used rubber hose to hook it up-- i dont know how long it would of lasted just used the car to get me to work and back
Old Nov 10, 2006 | 07:23 PM
dinko's Avatar
Default Re: Can I use regular heater hose on back of block? (qfast817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 &raquo;</TD></TR><TR><TD CLASS="quote">i used a brass pipe u-bend and then used rubber hose to hook it up-- i dont know how long it would of lasted just used the car to get me to work and back</TD></TR></TABLE>
haha creative.
i might just call acura and talk to them. i thought honda-tech would be the easiest place to find this answer.
Old Nov 11, 2006 | 01:49 PM
dinko's Avatar
well i ended up getting a prebent piece of hose from car-quest. i went to like 4 different auto stores before i found exactly what i wanted. anyways...part # 18400 by car quest. fits perfect just had to trim it a little bit.
that takes care of the coolant leak...now i have an oil leak from hell... sweet
9thgenidiot
Mar 26, 2016 09:27 AM
Jibin
Apr 24, 2010 07:42 PM
MenaceL.A.671
Sep 14, 2005 04:36 AM
Superhatch
Jul 14, 2003 06:26 AM
