What ecu should I use?
Old Nov 10, 2006 | 12:34 PM
90_civic_Si's Avatar
Default What ecu should I use?
I just swaped in a DOHC ZC and it`s running great but i`m using my pm6. I know i should use either the 88-89 integra(pm7) or even better the pg7(ZC) but will these make any difference in performace or just use more gas.
I just want to know what is the best to use as far as gas mileage and best performance. I want to use the pg7 but people say theres not much difference and it just burns more fuel. Let me know cuase i don`t really want to waste the money and end up spending more money for nothing. Thanks for any info.
Old Nov 10, 2006 | 12:39 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: What ecu should I use? (90_civic_Si)
If you want better gas mileage stick with the PM6. The PG7/PM7 have a little more agressive fuel mapping, but the PM7 seems to run less rich than the PG7 becuase it's for a manual trans, not an automatic. Although I've yet to run a PM7 progam on my ECU, I can definitely tell you that the PM6 will improve your gas mileage. I run a PG7 and it always seems to run richer.
Old Nov 10, 2006 | 12:46 PM
Default Re: What ecu should I use? (wiZCo)
Thats what i wanted to know. The pm6 runs the engine fine, i just didn`t know what was best to use. Some guys say holy **** the the pg7 it`s like adding 100 horse power or stupid **** like that.
If i`m not gonna notice any difference other than spending more at the pumps than i`ll stick with my pm6. Thanks for clearing that up.
Old Nov 10, 2006 | 12:59 PM
Tippyman's Avatar
PG7 will give you 700 extra RPM than the PM6 and will richen the mixture up a bit.
Old Nov 10, 2006 | 01:24 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_civic_Si &raquo;</TD></TR><TR><TD CLASS="quote">I just swaped in a DOHC ZC and it`s running great but i`m using my pm6. I know i should use either the 88-89 integra(pm7) or even better the pg7(ZC) but will these make any difference in performace or just use more gas.
I just want to know what is the best to use as far as gas mileage and best performance. I want to use the pg7 but people say theres not much difference and it just burns more fuel. Let me know cuase i don`t really want to waste the money and end up spending more money for nothing. Thanks for any info.</TD></TR></TABLE>
the 88-89 Integra is PG7 and the DOHC ZC is PM7 - performance will be better with PG7/PM7 than with PM6 - it will not use significantly more fuel - the ECU will read the O2 sensor and adjust fuel accordingly
Old Nov 10, 2006 | 02:21 PM
Default Re: What ecu should I use? (jlicrx)
Thats right pm7 is the ZC ecu, oops. I even read the thread before i hit post and still got it backwards. I can get the pm7 for nothingm, i think i`ll try it out for a week or so and see if there`s any real difference.
HONDA-2NR
Feb 1, 2004 09:40 PM
SiB16A
57
Sep 15, 2003 02:17 AM
xstalkrx
Apr 18, 2003 10:04 AM
