Honda S2000 Honda S2000
OEM lip and spoiler questions
Old Nov 10, 2006 | 07:26 AM
Nims's Avatar
Default OEM lip and spoiler questions
Hi all,
I'm selling my AP1, and I had a few questions about the OEM aero.
I had the dealer add them because of a screw up on their end when I bought the car, so I'm not familiar with the installation/removal.
I know that with the spoiler, the trunk is drilled. My question on the spoiler is how easy would it be to switch trunks with a non-spoiler, and is that something anyone is actually interested in, or is it too much effort.
For the lip. If I just pull the lip off, will the front bumper show signs that it was installed, or can I just remove it cleanly.
Thanks for the info.
-james
Old Nov 10, 2006 | 08:08 AM
cmdr430's Avatar
Default Re: OEM lip and spoiler questions (Nims)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nims &raquo;</TD></TR><TR><TD CLASS="quote">
switching the trunk should not be to hard, but if you switch the trunk the vin# will not match the rest of the vin#s....
may not be fun to explain why they do not match....
it will shows signs that one was intstalled, aside from scratches from where it touches the bumper cover( hopefully it will wax out), also there will be an extra screw hole in the front wheel fender portion of the bumper cover.....
Old Nov 10, 2006 | 08:23 AM
Nishant's Avatar
Doing a trunk swap is prob not worth the effort. Most ppl will like it.
As per the front lip, its pretty easy to remove. Once removed though, you will see a difference in colors/rock chips/scratches. It will be obvious to any buyers that you once had a lip and they may queston why it was removed.
Overall, I think its best to leave them on there. Resell value isn't much on those two.
Old Nov 10, 2006 | 11:40 AM
Mr. Projekt's Avatar
* B A N N E D *
OEM lips are usually installed with the double-sided foam tape, so damage to the bumper should only be limited to glue and scuff marks.
As for the trunk, the swap is pretty straight forward, but adjustment takes a finer touch, and 2 people.
Old Nov 10, 2006 | 11:55 AM
cmdr430's Avatar
Default Re: OEM lip and spoiler questions (FR-MOB: Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">OEM lips are usually installed with the double-sided foam tape, so damage to the bumper should only be limited to glue and scuff marks.
no double sided tape on mine when i installed it....
Old Nov 10, 2006 | 11:58 AM
* B A N N E D *
Default Re: OEM lip and spoiler questions (cmdr430)
It helps to a certain point. I think it helped my CF lip a lot more than it did with the softer OEM ABS plastic piece.
Old Nov 10, 2006 | 12:18 PM
iam7head's Avatar
no one mention about the lock cylinder on the trunk?
Old Nov 10, 2006 | 12:22 PM
* B A N N E D *
Default Re: OEM lip and spoiler questions (iam7head)
It's one plug and a couple of plastic clips, you don't have to swap the actual lock cylinder OR the 3rd brake light.
B18ls*RAYON's Avatar
double sided tape=AP2 lip
Old Nov 10, 2006 | 12:37 PM
* B A N N E D *
Default Re: OEM lip and spoiler questions (B18ls*RAYON)
Reading &gt; me. Disregard.
AlwaysFresh
Honda Civic (2006 - 2015)
24
May 26, 2007 05:16 PM
I Want An Si
Aug 27, 2003 09:47 AM
ramz7887
Jul 1, 2003 05:25 PM
