STUMPED: CAR WON'T MOVE FORWARD!?
Old Nov 10, 2006 | 01:03 AM
Marco93EJ's Avatar
Default CAR WON'T MOVE FORWARD (PASS. SIDE TIRE SPINS, BUT NOT DRIVERSIDE)
I replaced my upper control arms, lower balljoints, and axles...and now my car wont drive!
<U>SCENARIO 1: CAR ON GROUND</U>
1)I shift to 1st and apply gas, but car doesn't move forward
2)I put it in REVERSE and apply gas, but car doesn't move backward either
i checked the axles to see if they popped out, but they did not (no fluid spill or anything)...so i decided to put the car back on the jack stands.
<U>SCENARIO 2: CAR ON JACK STANDS</U>
1) repeated step 1 & 2 above...the passenger side tire spins, but the driverside tire doesn't
could the right rotor be seized? (ive had these spindles out in the weather for a few months before i put them back on tonight)
i applied some PB blast around the area of the rotor where it meets the caliper (maybe a bad idea). the rust seems like the reason why its seized. These spindles were fine a few months ago (i had LS spindles installed until now)
HELP ME OUT, HT! Thanks! -- Marc
Old Nov 10, 2006 | 01:55 AM
boosted_slow's Avatar
Default Re: CAR WON'T MOVE FORWARD (Marco93EJ)
the final drive is a two pice one for right one for left i had the same problem i snaped the the ring gear in the tranny the wild thing is it would still move (1 out of 30 trys other then that just reved up if you put you finger in the tranny holes where the axles go you can try to move it back and forward try this let me know
rll2
Jan 7, 2013 08:21 AM
SIRIUS VTEC
Dec 23, 2010 07:48 PM
mdanish
Mar 17, 2010 11:40 AM
jascon
Honda Civic (2006 - 2015)
11
Mar 6, 2007 04:16 PM
