y7 timing belt z6 head?
i need to kno from sumone who actually knows... cause people are saying u need the z6 belt and others are sayin you can use the y7 WHATS THE REAL ANSWER
why dont u try it? if your motor gets messed up badly, or u just end up wasteing a few hours for nothing if its too big or too small.. then you can ask yourself.. is it really worth the 30 dollars or so, u would spend too get the CORRECT timing belt? and do it ONCE?
some people never learn.. skimp or try too shortcut measly costs.. end up paying ten times or more in repairs after that shortcut fails
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pho^k »</TD></TR><TR><TD CLASS="quote">nope you gotta use a z6 or a y8 timing belt...y7 timing belts are different...meaning the teeths on the timing belt...</TD></TR></TABLE>
y7 and y8 belt are the same. z6 may be different, but i've never tried it.
to OP, are you just changing the belt on your z6, or did you do a head swap?
i did the head swapi put a z6 on a y7 block.. i have the belt thats not that issue at all.. the problem is me being able to get the crank pully off...i want to kno if its nessassary or not.. and the belt DOES fit on the gear.. but there is a one tooth difference i think but wouldnt it be ok to use my y7 cam gear?
Modified by Cashieboi at 11:30 AM 11/12/2006
the Y7 belt has too many teeth, and changing cam gears won't help. you won't have the right belt tension, it'll be out of time a bit, you'll have premature belt failure, and risk bending a valve, so enough people have told you the correct way to do it....so go ahead and use the Y7 belt, while your at it pour some metal shavings in your crankcase, and drain all your coolant and replace it with maple syrup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk_duece »</TD></TR><TR><TD CLASS="quote">the Y7 belt has too many teeth, and changing cam gears won't help. you won't have the right belt tension, it'll be out of time a bit, you'll have premature belt failure, and risk bending a valve, so enough people have told you the correct way to do it....so go ahead and use the Y7 belt, while your at it pour some metal shavings in your crankcase, and drain all your coolant and replace it with maple syrup. </TD></TR></TABLE>
That motor would be delicious.
i just dont understand why u would need that belt... cause the gears are the same so wouldnt that mean that the belt would be the same..i just dont understand how this works..
THANK YOU WTF THANK YOU **** I LOVE YOU, you switch the belt if your doing the swap on a damn eg d15, i swear the belt fits perfect which is why i dont understand why people are saying you have to switch it... THANK YOU so now i kno thats not the problem thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hitatree.at125mph »</TD></TR><TR><TD CLASS="quote">well works fine for me 380whp </TD></TR></TABLE>
380whp and you run a 12.3? What are you towin a boat when you run? Might have something to do with the fact the your timing belt has more give than the pillsbury doughboys belly when you poke it......
ok heres the story
i had a y7 engine stock blew it to hell and back
bought a bare Y8 block put my y7 crank crank pully oil pump water pump with some srp pistons and eagle rods.. with my y7 head
ran 12.3 116 280whp
bought a z6head ploped it on my engine and used my y7 belt made 300+whp
ohh the y7 and y8 block are identical cept that lil stamp on it
and the oil pan but everyhtng is hybrid on them
ran 12.3 116 280whp
