Whats Wrong with your EF today?
Old Nov 9, 2006 | 07:58 PM
Vovchandr's Avatar
Default Whats Wrong with your EF today?
Spinoff of the other thread.
List everything that you feel like is broking, not upto par, or planing to fix.
Mine:
Sunroof wont close but will open.
Leaks in the back by the spare.
Blower motor gone.
Pass side vent broke.
Idle wont stay solid.
Lose ground.
Unbalanced wheels.
Thats it for now.
Keep em coming.
Edit 11/11/06 : If you already listed a problem list, and then fixed something, you can requote yourself later saying what you fixed.
If somebody is going through this thread and found that he has the same problem as you fixed, you might be able to help a fellow EF brother out.
Edit 2 11/11/06
THIS IS NOT a plan to do thread. Do not list your planned after market mods here.
Just the things that are wrong with the car that makes it off factory spec, or make it act or behave in "non normal" ways in which it shouldnt if it was "normal"
DO not list planned mods, period.
Modified by Vovchandr at 9:35 AM 11/11/2006
Modified by Vovchandr at 10:04 AM 11/11/2006
Modified by Vovchandr at 10:06 AM 11/11/2006
Old Nov 9, 2006 | 08:00 PM
Pee Wee's Avatar
Default Re: Whats Wrong with your EF today? (Vovchandr)
those are all easy fixes
Old Nov 9, 2006 | 08:02 PM
4dOoR-Ex's Avatar
needs new ball joints...
Old Nov 9, 2006 | 08:11 PM
Hondacivic90ed's Avatar
tires are bald
pass axle boot leaks
exhaust hanger allows exhaust to periodically slide into frame
driver front speaker rattles
rear drums are gay
no rear sway bar is gay
stock springs/shocks
Old Nov 9, 2006 | 08:24 PM
eda6's Avatar
Default Re: Whats Wrong with your EF today? (Hondacivic90ed)
i've been pinpointing all the rattles in my car and dealing with them. Doors and steering rack rattle. ordering new door lock rod holders, and lockrod cushions for the doors. ordering new rack end bushing, bearing and lock washers to rebuild the steering rack.
after those parts are installed i'm rebuilding the brake calipers and buying the parts to make the car watertight.
Old Nov 9, 2006 | 08:39 PM
IndySporty's Avatar
- Need to remove GSR block with 0 compression on #1 and install fully built B16 block recieved monday
- Need to replace GSR transmission with 5th gear snatched out with LS transmission with all 5 gears working properly
- Need to hook up wideband and re-wire entire car to OBD-1
- Need to figure out why speedometer isn't working since electronic VSS conversion
Old Nov 9, 2006 | 09:53 PM
thirteen20CRXSi's Avatar
need trans driving daily on 1st and 5th sucks dick
need ctr cams for the b series so i can put it in to take care of trans problem on single cam
Old Nov 9, 2006 | 09:55 PM
michael O's Avatar
Default Re: (IndySporty)
1. my deck doesn't play cd's any more
2. My master cylinder appears to be shot
3. the key marks are still covering both sides of my car
4. the weatherstripping around the rear hatch is peeling and it's half chrome, half rubber
5. It's leaking a little bit of oil//tranny fluid
6. I'm still rolling on 13" steelies w **** tires
7. The AC compressor is seized
8. Interior is full of cigarette burns and smells horrible half the time
9. I also can't get the seats clean
10. It doesn't start half the time cuz my ignition wiring is messed up and I have to jump the battery to the starter.
Old Nov 9, 2006 | 10:25 PM
4thgenhtch's Avatar
Default Re: (michaelOlson)
This threads funny
hmmm
Tranny is shot
wierd random fuel smells
Interior
paint
I could deffenetly keep going hehe
Old Nov 9, 2006 | 10:50 PM
Cheeech's Avatar
Motor
Old Nov 9, 2006 | 11:13 PM
jeremiah963's Avatar
Default Re: (CheechJDM)
my car wont turn off
idle is really rough but still drives fine
need alignment
need a new bumper
theres probly more i just cant think its too late lol
Old Nov 9, 2006 | 11:32 PM
Spoon Sports's Avatar
Suit up
Default Re: (jeremiah963)
my brake fluid keeps disappering/ draining quickly.
Old Nov 9, 2006 | 11:35 PM
90sedan's Avatar
hatch
- need to fix front end damage
- buy new tires
- replace bent rim
- alignment
- replace brakes/turn rotors
- replace drivers seat
- fix leaks
sedan
- pass emissions
- get insured
- install alarm
- replace brake light bulb
Old Nov 10, 2006 | 03:03 AM
SETI20's Avatar
Tail light leaks into hatch.
Steering rack bushing.
Reaction rod bushing.
Rusty arches.
Foggy windows.
Old Nov 10, 2006 | 03:12 AM
DmcL's Avatar
haha finally a thread for me...
lets see..
need to replace a front CV joint, rear wheel bearing/hub assembly, rear trailing arm bushing, possibly main relay starting problem, cracked front windscreen, rear tyres that lose about 5psi a day, rusted drivers side window slider (cant roll window down more than 2/3 or it comes off the tracks), alternator belt sometimes squeaks, needs an oil/filter change, no idea when timing belt was last done if ever, small hole in driver side sill, clutch release bearing makes darth vader noises, randomly sticking back caliper.
i think thats it lol
Old Nov 10, 2006 | 04:21 AM
Twilight's Avatar
Default Re: (SETI20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">Tail light leaks into hatch.
Rusty arches.
Foggy windows.</TD></TR></TABLE>
How familiar, my friend.
-Steering rack bushing
-Foggy windows
-Taillight leaks a bit into the trunk
-Front alignment
-Too low for winter
-Right side CV joint keeps clicking
Old Nov 10, 2006 | 05:12 AM
Ti Rider's Avatar
Good thread. Maybe it will get me off my couch to fix this stuff -
1. Bad pass. side CV joint
2. Bad bushings
3. Leaky valve cover gasket
4. Time for new timing belt/waterpump
5. Still have the original o2 sensor
Old Nov 10, 2006 | 06:14 AM
dr_latino999's Avatar
Default Re: Whats Wrong with your EF today? (Ti Rider)
Need to replace both knuckles
Need to remove broken studs from valve cover
I should fix my power locks eventually.
Old Nov 10, 2006 | 06:24 AM
24psi's Avatar
Default Re: Whats Wrong with your EF today? (dr_latino999)
needs a new motor, fix flat tire, put in si dash thats in the back, rear disk swap needs to be done, fix radiator, probably some stuff i'm forgetting
Old Nov 10, 2006 | 06:29 AM
v8Buster's Avatar
89 CRX Si
-rear trailing arm bushings
-bald rear tires
-weather stripping all around the car
-heat gauge doesnt work
-hood sometimes doesnt unlatch unless you have 2 people
-need the propper screws for the passenger side tranny mount
-seats have rips
-broken passenger side mirror glass(fixing today)
-oil change coming up
Old Nov 10, 2006 | 06:30 AM
cbp_crx's Avatar
Default Re: Whats Wrong with your EF today? (24psi)
my rex has an engine miss from hell
need a new tire because one blew out on me yesterday
needs the fender linings before winter comes, but havent found any good ones
Old Nov 10, 2006 | 09:00 AM
junior40er's Avatar
Default Re: Whats Wrong with your EF today? (cbp_crx)
88 CRX HF:
*need to figure out why temp gauge acts funny after a bit of driving. (sudden jump to hot occasionaly)
*shot springs/shocks
*need to add to insurance policy.
*need to smog but not sure if it'll pass with new motor.
*hatch leaks when I wash the car or when it rains.
*no radio.
Old Nov 10, 2006 | 09:03 AM
b18sihatch's Avatar
Mines a Project
Old Nov 10, 2006 | 09:31 AM
bagpipe goatee's Avatar
Default Re: Whats Wrong with your EF today? (b18sihatch)
Well, I was driving down the road, and everything just plum fell off of it:
I guess it wants me to restore it or something.
Old Nov 10, 2006 | 09:34 AM
soon to be boosted ZC's Avatar
89 CRX SI
time for a new drivers side axle
fix leaks
need new shocks
need a tune up badly
put rear interior back in
need different winter tires
paint is fading away
thats it for now
