ST rear sway bar on crx dx
i just basically wanted to know if anyone has pictures of the suspension techniques rear sway bar installed on a crx dx or hf. Can a rear lower tie bar be used in conjunction as well i.e. dc sports???? I also have function 7 lcas installed if it makes a difference in installation. any pics or info is appreciated. thanks
installation on the dx is the same as an si. a lower tie bar can be used, and yes you can use function 7's and it will work fine. if you want pics search in the rr/ax forum there are many pics of this setup
MBDiagMan
Oct 27, 2004 11:12 AM
crexer
Aug 30, 2004 07:03 PM
elmalouno
Feb 24, 2004 04:02 PM
