91 crx, problems starting.
Old Nov 9, 2006 | 06:15 PM
mathew206's Avatar
Default 91 crx, problems starting.
I'm having issues starting the car. I just bought it from my friend, and I just can't get it to go. I just put in a new battery. We tested for fuel to the motor. There was nothing. So I replaced the fuel pump and fuel was going to the engine. I did the main relay check, and I hear 3 clicks (searched from forums), so i assume that's working. My friend said he just changed parts in the distributer about 6 months ago. The ecu does make a noise when I turn the car on. I'm not sure what that is or if it's significant. I just started the car today on the first try after not being able to start it on Monday. However, once i drove it to the destination, I could not get it to start again.
Old Nov 9, 2006 | 07:09 PM
mahatma's Avatar
Default Re: 91 crx, problems starting. (mathew206)
so it will crank but not start up?
Old Nov 9, 2006 | 07:20 PM
PnkRokCountryboy's Avatar
Default Re: 91 crx, problems starting. (mahatma)
If it doesnt crank, check the starter. Mine went bad out of nowhere.
If it does crank, check for spark and compression.
Old Nov 10, 2006 | 12:18 PM
mathew206's Avatar
Default Re: 91 crx, problems starting. (PnkRokCountryboy)
It cranks, but it doesn't turn. It only started one time. If the car started, shouldn't the starter be okay? How do I check for compression? I was going to change out spark plugs soon.
Old Nov 13, 2006 | 12:20 PM
crazyemokid's Avatar
Check the dizzy, I had the exact same problem and that was it.
Old Nov 15, 2006 | 10:50 AM
mathew206's Avatar
I changed the sparks today.. It wouldn't start.. I added some gas.. and miraculously.. it started. However, once it stopped, it wouldn't start again. Do you think the distributor is still bad? The ecu is also beeping 6 times when i turn it on.. I'm sure that code means something.
Old Nov 15, 2006 | 01:11 PM
roterx7's Avatar
check to see if the wire on the starter came unpluged. it looks like a speaker wire. also check your starter fuse
Steven Quayle
Mar 6, 2018 10:40 AM
91civicsikid
Dec 30, 2009 12:36 PM
munchies91crx
10
Aug 22, 2009 08:54 PM
Audio28
Jul 3, 2003 05:33 PM
91GreyAccord
Jul 20, 2002 11:09 PM
