cr-x carb setup
Old Nov 9, 2006 | 01:44 PM
wlmcclsky's Avatar
Default cr-x carb setup
having problem getting carbs balanced on my 1.5 dual carb cr-x uneven idleing loss of power e.t.c any suggestions?
Old Nov 9, 2006 | 02:36 PM
Lasty K's Avatar
Default Re: cr-x carb setup (wlmcclsky)
This is probably the wrong forum to ask, try asking here -> https://honda-tech.com/zeroforum?id=3
Old Nov 9, 2006 | 08:17 PM
Crx Jimmy's Avatar
switch to the 1.3L carbs and you wont need any of that electronic stuff on them. just run a manual choke
Old Nov 10, 2006 | 12:05 AM
~sp33~'s Avatar
EFB055
Cruddy idle and power loss, could be your air/fuel mix. Theres a screw you turn between the two carbs which adjusts it. I cant think which way to turn it though, id say try slightly either way from the position that its in and see what difference it makes.
Edit: huzzuh, 800 posts.
Old Nov 10, 2006 | 07:08 AM
Cyclonium's Avatar
You from Coleraine, NIreland?
Should sign up to http://www.cr-x.org/home
and http://www.hondacrx.co.uk
People may have answers for you there
I answered a few questions on cr-x.org about carbs gave a link to the honda concerto manual which has the same setup as our dual carbs so should help balancing them.
Also, maybe check/change fuel filter, air filter and get some carb cleaner when you at it.
If balancing the carbs doesnt work check timing
88crxvtec
Appearance Build Threads
May 29, 2014 05:27 PM
patrick theHman
Aug 14, 2009 06:47 PM
louisiana CRX
Dec 1, 2008 05:37 PM
Pylon_Boy
Nov 29, 2004 01:57 AM
crxforum
May 17, 2003 08:02 AM
