will the SI sway bars bolt....
Old Nov 9, 2006 | 01:31 PM
rewerbcrx's Avatar
Default will the SI sway bars bolt....
will the SI lower sway bars bolt into my HF? looking to get lower sways and was curious if they did and whether i should but ST sways
Old Nov 9, 2006 | 01:33 PM
Tyson's Avatar
Default Re: will the SI sway bars bolt.... (rewerbcrx)
no it wont bolt up. there are holes where the bracket goes, but its not threaded. you can either weld a bar to the bracket so it bolts to the tow hook holes, or you can fish a bolt in the frame by removing the bumper, or drill a hole from inside the car to access the hole from above.
Old Nov 9, 2006 | 01:34 PM
rewerbcrx's Avatar
Default Re: will the SI sway bars bolt.... (Tyson)
so is there anything else i can do besides that to get the lower sways?
Old Nov 9, 2006 | 01:35 PM
Tyson's Avatar
what?
Old Nov 9, 2006 | 01:37 PM
rewerbcrx's Avatar
so wait... a set of suspension techs sway bars wouldn't work either huh?
because the lack of a bracket?
Old Nov 9, 2006 | 01:40 PM
Tyson's Avatar
ST uses the tow hooks with their own bracket. thats why i mentioned making your own bracket to adapt the stock bracket.
https://honda-tech.com/zerothread?id=1146145
and they also have brackets to mount ot the lower control arm, which you also will need if you wanted to stay stock.
Old Nov 9, 2006 | 01:44 PM
rewerbcrx's Avatar
i just looked at that thread before i checked back on this one... what i don't understand is thats all not for my car....
91hf crx
Old Nov 9, 2006 | 01:45 PM
Tyson's Avatar
what?
Old Nov 9, 2006 | 01:50 PM
rewerbcrx's Avatar
okay... i am one of those idiots that need it just said...
~~~ so as long as i buy the ST sway bars i do not have to modify my car? but do they work just as well? second... ??the 91hfcrx doesn't have these holes for the brackets correct??... i was under the asumption that the 91crxhf had all the holes for the sway bars that are on the si
Old Nov 9, 2006 | 01:53 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx &raquo;</TD></TR><TR><TD CLASS="quote">i was under the asumption that the 91crxhf had all the holes for the sway bars that are on the si </TD></TR></TABLE>
bad assumption. only Si civic and crx's had provisions for rear swaybar. like i said...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">no it wont bolt up. there are holes where the bracket goes, but its not threaded. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">ST uses the tow hooks with their own bracket.
and they also have brackets to mount ot the lower control arm, which you also will need if you wanted to stay stock.</TD></TR></TABLE>
the complete ST kit is all you need. its designed for non-Si CRX/Civics.
it is however 22mm. and maybe you dont need a 22mm.
in that case, you need to modify the stock parts like in that thread and get Si lower control arms so it will work.
Old Nov 9, 2006 | 02:07 PM
rewerbcrx's Avatar
what about the front? thank you for clearing up for the rear
Old Nov 9, 2006 | 02:09 PM
Tyson's Avatar
fronts are interchangeable.
you have the smallest available swaybar up front. to some ppl, thats actually a positive thing. you just need the bushings to go along with the swaybar if you switch it out.
DX and Si front swaybars are the same. sedan swaybars are a bit bigger. DA integra swaybars will fit and are the biggest, but hollow.
Old Nov 9, 2006 | 02:15 PM
rewerbcrx's Avatar
now that i think about it i am not sure if mine are even on the car... i will have to get under it and look. hehehehe maybe thats why its so squirly
tron_
Suspension & Brakes
May 11, 2012 07:05 AM
beebeecivic
Suspension & Brakes
Mar 13, 2011 07:57 PM
Integra4lyfe069
Nov 17, 2010 04:41 PM
92_prelude
Apr 16, 2007 05:17 PM
denshu
Jul 5, 2003 02:16 PM
