Itr transmission input shaft bearing going out.
Old Nov 9, 2006 | 12:45 PM
shivic's Avatar
Default Itr transmission input shaft bearing going out.
i want to replace the input shaft bearing and oil seal on my itr transmission. i'm not sure if the part number is the same for a gsr or b16 transmission.
thanks for the help.
Old Nov 10, 2006 | 04:59 AM
BoBo Racing's Avatar
Default Re: Itr transmission input shaft bearing going out. (shivic)
b16 i believe
Old Nov 10, 2006 | 11:59 AM
shivic's Avatar
Default Re: Itr transmission input shaft bearing going out. (BoBo Racing)
can anyone verify this?
Old Nov 11, 2006 | 08:56 AM
RTW DC2R's Avatar
same as B16 (all B series are probably same as well). order it from Honda its cheaper.
Modified by RTW DC2R at 1:14 PM 11/11/2006
Old Nov 11, 2006 | 02:29 PM
Bense's Avatar
Default Re: (RTW DC2R)
I'm not sure if they're the same, they should be. (gsr/b16 that is)
but if it's a b16a2 one, then:
2000 civic si, ISB
91002-PS1-003 BEARING, BALL (28X60X15) $33.23 from local dealer, $24.52 from hondapartsdeals.
I'd just get it from the local dealer to save on shipping.
Old Nov 11, 2006 | 02:31 PM
Bense's Avatar
Default Re: (Bense)
2001 Acura Integra Type R, input shaft bearing
91002-PS1-003 BEARING (28X60X15)
http://www.acuraoemparts.com/d...ch=no
Old Nov 11, 2006 | 03:10 PM
98DC2R's Avatar
Default Re: (Bense)
They may not have the same part numbers but there are all the same size bearings, inner/ outter diam.
Edit: read post above^^^
Old Nov 11, 2006 | 03:22 PM
D's Avatar
D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shivic &raquo;</TD></TR><TR><TD CLASS="quote">DA- totalled canyon racing</TD></TR></TABLE>
lol
Old Nov 11, 2006 | 05:01 PM
Default Re: Itr transmission input shaft bearing going out. (D)
they do have the same part number i work at a honda dealership
Old Nov 11, 2006 | 06:56 PM
RTW DC2R's Avatar
you people dont listen. I just replaced these a couple weeks ago.
Old Nov 11, 2006 | 07:33 PM
Bense's Avatar
proving you correct sir
rnouri
Honda Civic (2001 - 2005)
Jun 28, 2012 09:50 AM
SneezinCD5
Transmission & Drivetrain
Oct 7, 2008 12:28 PM
376R
Jun 12, 2005 09:58 AM
zman
Aug 4, 2004 11:55 AM
