Dpfi to Mpfi using the mpfi engine harness?
Old Nov 9, 2006 | 11:36 AM
1 Fly SI's Avatar
Default Dpfi to Mpfi using the mpfi engine harness?
Is there a post somewhere that they used the si engine harness in a dx body? All the stuff i find is with the original dx engine harness. I am attempting to use the crx si engine harness with the dx body harness. Where should I start?
Old Nov 9, 2006 | 11:43 AM
dr_latino999's Avatar
Default Re: Dpfi to Mpfi using the mpfi engine harness? (1 Fly SI)
You can't use the SI harness unless you depin all the tower connectors and work from there. Believe me when I say it's much easier to scavenge the plugs you need from the SI harness and integrate it with the stock harness.
Old Nov 9, 2006 | 11:51 AM
1 Fly SI's Avatar
Default Re: Dpfi to Mpfi using the mpfi engine harness? (dr_latino999)
I don't have the harness my friend recieved the dx shell with no motor but it had a ls motor in it before. It looks like the tower connectors have been repinned already. This is what it is doing.
https://honda-tech.com/zerothread?id=1805491
BlendedEM1
Feb 13, 2011 07:06 PM
shackler
Mar 22, 2007 07:21 PM
HondaHeddie
27
Oct 6, 2006 07:57 PM
Argetnia
Apr 7, 2005 11:54 PM
mobrep
Jan 5, 2004 05:31 AM
