I dont knoe the diffrence 205 or 215 :(
ok guys,u wanna either get 205/45/16 or 215/45/16 i really dont know the diffrence
can soemone post pics of diffrence or just tell me...sorrryyy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikes2000civicsi »</TD></TR><TR><TD CLASS="quote">ok guys,u wanna either get 205/45/16 or 215/45/16 i really dont know the diffrence
can soemone post pics of diffrence or just tell me...sorrryyy</TD></TR></TABLE>
The difference is, the 215 is 10mm wider, with a slightly larger total diameter.
Use the correct size for your car though, which should be a 205/45-16 for a 00 Civic Si.
can soemone post pics of diffrence or just tell me...sorrryyy</TD></TR></TABLE>The difference is, the 215 is 10mm wider, with a slightly larger total diameter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 »</TD></TR><TR><TD CLASS="quote">on a 2000 si both sizes are recommended for your car</TD></TR></TABLE>
lol WTF are you talking about? Recommended by who? Please back your statement.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.MONEY »</TD></TR><TR><TD CLASS="quote">
lol WTF are you talking about? Recommended by who? Please back your statement.</TD></TR></TABLE>
So what 16" tire size do you think is recommended then huh?
Both 205/45/16 and 215/45/16 give you the closest to stock diameter (195/55/15) which preserves the odometer and speedometer readings. 215/45/16 has very very limited choices for tires and are overpriced so go with 205/45/16 which has a much wider selection of tires.
You can use either size - 205/45-16 or 215/45-16 - on an Integra or '97-00 Civic. 205/45 is slightly smaller in diameter than stock, and 215/45 is slightly bigger, but both are within 1 percent of the stock outer diameter.
Most tires are available in 205/45-16 or 215/45-16, not both. So decide on what kind of tire you want to get, and then see what size it comes in. For example, if you want to get the Kumho Ecsta SPT summer tire (great combination of performance and value), or the Kumho Ecsta ASX all-season tire, then you should get 205/45-16, because that's the size they come in. If, OTOH, you want to get the supersticky (but fast-wearing) Falken Azenis RT-615 summer tire, then you should get 215/45-16, because that's the size it comes in.
honda recommends 195/55/15 for civic si's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KoketsuCivicSi »</TD></TR><TR><TD CLASS="quote">honda recommends 195/55/15 for civic si's</TD></TR></TABLE>
It's difficult to mount 195/55-15 tires if you have 16-inch wheels.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay »</TD></TR><TR><TD CLASS="quote">
Both 205/45/16 and 215/45/16 give you the closest to stock diameter (195/55/15) which preserves the odometer and speedometer readings. 215/45/16 has very very limited choices for tires and are overpriced so go with 205/45/16 which has a much wider selection of tires.</TD></TR></TABLE>
a 215 is quite wide; if he's lowered it will probably rub.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">It's difficult to mount 195/55-15 tires if you have 16-inch wheels.
i'm just saying that honda recommends 15-inch sizes. my reply was not intended for the original poster
</TD></TR></TABLE>i'm just saying that honda recommends 15-inch sizes. my reply was not intended for the original poster
205 means 205mm wide, 215 means 215mm wide
can soemone post pics of diffrence or just tell me...sorrryyy</TD></TR></TABLE>205 means 205mm wide, 215 means 215mm wide
Jer'rome
Honda Civic (2001 - 2005)
Jun 25, 2007 05:06 AM
