RTA matches, which teg fits? (searched)
Old Nov 9, 2006 | 07:20 AM
HondaHeddie's Avatar
Default RTA matches, which teg fits? (searched)
I have a 91 crx DX with bushings that have 250k on them
you can imagine how they look
I plan to do the disc brake swap in the future
should I look for crx si rta's or teg rta's?
can I grab the ?sway?bar(I forget the full name) from either to mount on the rta's when I swap these? or do I need a special one to fit a dx?
Old Nov 9, 2006 | 10:45 AM
funkified's Avatar
Default Re: RTA matches, which teg fits? (HondaHeddie)
theres topics all the time about this, i made one a little while ago. so just search!
i believe the 90-91 crx si rta's will swap right over w/ ebrake cables too. and 90-93 DA rta's will also work but i think you can use crx cables too, but i know that hatchbacks need DA cables for it to work. someone correct me if im wrong.
Old Nov 9, 2006 | 11:53 AM
Default Re: RTA matches, which teg fits? (funkified)
give me a topic to search for
I could not find it when I searched
everything I found was about bushings
Old Nov 9, 2006 | 11:54 AM
EL Vap133's Avatar
https://honda-tech.com/zerothread/1508680
https://honda-tech.com/zerothread/642479
Old Nov 9, 2006 | 03:01 PM
funkified's Avatar
Default Re: RTA matches, which teg fits? (EL Vap133)
how bout trying any combination of the following words.
rear disc/disk/brake swap/conversion
Old Nov 9, 2006 | 03:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by funkified &raquo;</TD></TR><TR><TD CLASS="quote">how bout trying any combination of the following words.
rear disc/disk/brake swap/conversion </TD></TR></TABLE>
the reason I was not using those words is that I wanted to research rta's not brakes
I need to replace my bushings badly but am thinking it would be better to replace the rta's so future mountings of disc's and sway bars are accomodated
but I will now look up "brakes" to learn about "rta's"
Old Nov 9, 2006 | 04:18 PM
FINALLY
after 6hrs of examination in the faq
buried deeper than Jimmy Hoffa
found my question plainly answered
no cryptic abbrv, or abstract ref's
http://www.fourthgenhatch.net/reardiscswap.html
Thanks temp
Old Nov 9, 2006 | 07:50 PM
ProjectDarkBlack's Avatar
ha ha 6hrs? there is a new one of these topics every 6 hours
Old Nov 9, 2006 | 08:00 PM
eda6's Avatar
88-00 civic/94+ teg TA bushings are the same. the 90-93 DA trailing arm is the oddball with a slightly bigger bushing.
Old Nov 10, 2006 | 09:42 AM
Default Re: RTA matches, which teg fits? (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">88-00 civic/94+ teg TA bushings are the same. the 90-93 DA trailing arm is the oddball with a slightly bigger bushing. </TD></TR></TABLE>
I am asking about the arm
not the bushing(the bushings dont matter till I have arms to put them in)
but from what I have found on my own, I will look for some 89-91CRXsi TA's
unless I get further correction.........
thanks guys
Old Nov 10, 2006 | 09:44 AM
Default Re: RTA matches, which teg fits? (ProjectDarkBlack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectDarkBlack &raquo;</TD></TR><TR><TD CLASS="quote">ha ha 6hrs? there is a new one of these topics every 6 hours</TD></TR></TABLE>
if that is the case then I guess answers arent posted as quickly
lol
musasabi
Oct 26, 2008 09:09 PM
sohcvtec91hatch
31
Jan 4, 2007 02:16 PM
HamiltonRex
Apr 23, 2004 04:18 PM
NikoZai
16
Mar 12, 2004 12:04 AM
crx1856
May 2, 2003 10:36 PM
