ls swap... any suggestions
Old Nov 9, 2006 | 04:22 AM
gottalovethe4door's Avatar
Default ls swap... any suggestions
hey ht...
I had an automatic y7 in my 98 sedan. I hydrolocked it so it needs to go. I found a 95 ls integra, and plan on swapping the motor/tranny/brakes to my car. I figure on getting a new clutch/timing belt/water pump... also a c.f. whale *****, egay headers, reuse my cat (magnaflow high flow, 2.5"), and get a new exhaust (get a bolt on 2.5" to replace my 2.25" crimp bent $75 special).
Is there anything else i should do to it know before i go ahead and do the swap, matbe oil pump or arp head studs... i dunno, just lookin for some input. (I plan on boost down the line, hopefully sooner than later).
thnx
Old Nov 9, 2006 | 05:36 AM
BauleyCivic's Avatar
Risky Business
Default Re: ls swap... any suggestions (gottalovethe4door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gottalovethe4door &raquo;</TD></TR><TR><TD CLASS="quote">i dunno, just lookin for some input.</TD></TR></TABLE>
Old Nov 9, 2006 | 05:40 AM
Statetrooper
Guest
Posts: n/a
Default Re: ls swap... any suggestions (BauleyCivic)
Swap it and drive it like you stole it.Good luck.
Old Nov 9, 2006 | 06:19 AM
Default Re: ls swap... any suggestions (Statetrooper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Statetrooper &raquo;</TD></TR><TR><TD CLASS="quote">Swap it and drive it like you stole it.Good luck. </TD></TR></TABLE>
... so you can pull me over... j/k thnx...
Old Nov 9, 2006 | 07:10 AM
klungemonger's Avatar
Mounts:
You need the side block mount and rear tranny bracket from a 99-00 Si. Not the rubber stuff, the parts that bolt to the swap itself. Your D-series a/c compressor won't bolt to the teg lower block bracket so you need to take one of the following steps: either discharge your system and install the Teg compressor w/condenser lines...OR...get a P54 or P7J a/c bracket which will allow you to bolt your D compressor onto the B block.
Electrical:
You have to keep your stock harness but need to do a few mods...
1) Do the 2-wire IACV plug conversion and swap the injector plugs in from the Integra, or get OBD2 Teg injectors so you can use your stock plugs.
2) You need to open up both your distributors and carefully remove the electrical guts, then swap them so you now have an OBD2 dizzy for your LS motor.
3) Get an OBD2a-OBD1 conversion harness so you can use that LS OBD1 ecu
4) You will also have to lengthen or relocate some harness plugs like the primary O2 sensor to reach where they need to be.
If you need to remain emissions compliant then I'd have to recommend some different steps for you about wiring. You can PM or e-mail me with any other questions, I put an LS in my 98 also.
Old Nov 10, 2006 | 11:04 AM
good stuff, thank you...
Old Nov 11, 2006 | 11:35 PM
skunkcoupe's Avatar
Default Re: (klungemonger)
What he said ^^^
GDM Z28
May 3, 2005 01:06 PM
JCritt
Nov 10, 2004 11:18 AM
choppystyx
Dec 11, 2002 07:56 AM
gixxer6
11
Nov 6, 2002 07:22 PM
