1996 JDM H22a -- Auto or Manual Tensioner?
Old Nov 8, 2006 | 10:37 PM
Propulsion's Avatar
Default 1996 JDM H22a -- Auto or Manual Tensioner?
Simple question, if you know it...
98vtec's Avatar
moderator emeritus
Default Re: 1996 JDM H22a -- Auto or Manual Tensioner? (Propulsion)
all h22's have an auto
Old Nov 8, 2006 | 10:47 PM
Propulsion's Avatar
Default Re: 1996 JDM H22a -- Auto or Manual Tensioner? (98vtec)
thanks for the quick reply. I guess it's time to get my shopping list together for the manual tensioner swap.
Old Nov 9, 2006 | 10:04 AM
rocket30004's Avatar
well since i'm an h22a noob, perhaps you guys can elaborate on why change to the manual tensioner (i'm assuming the auto one is subject to premature failure...? [and if so, did honda ever release an updated part?] )
Old Nov 9, 2006 | 10:10 AM
OaksRacing's Avatar
Default Re: 1996 JDM H22a -- Auto or Manual Tensioner? (rocket30004)
We have ran both manual and auto - we have not had any problems with either set up.
Old Nov 9, 2006 | 10:21 AM
98vtec's Avatar
moderator emeritus
Default Re: 1996 JDM H22a -- Auto or Manual Tensioner? (OaksRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OaksRacing &raquo;</TD></TR><TR><TD CLASS="quote">We have ran both manual and auto - we have not had any problems with either set up.</TD></TR></TABLE>
but you know that the auto's have their issues. Especially when you add a set of stiffer valvesprings.
Old Nov 9, 2006 | 10:33 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">
but you know that the auto's have their issues. Especially when you add a set of stiffer valvesprings.</TD></TR></TABLE>
This is true. Thats great that Oaks Racing has not had any problems but the potential for tensioner failure is real. Why risk engine damage when for under $200 you can buy insurance in the form of a manual tensioner.
Old Nov 9, 2006 | 10:48 AM
BB2H22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocket30004 &raquo;</TD></TR><TR><TD CLASS="quote">well since i'm an h22a noob, perhaps you guys can elaborate on why change to the manual tensioner (i'm assuming the auto one is subject to premature failure...? [and if so, did honda ever release an updated part?] )</TD></TR></TABLE>
They're just know to have problems. Its has a little hydrolic piston that keeps tension on the belt. Put enough of a beating on it, it'll probably go bad. You can get a manual tensioner off of an H23 or F22.
Old Nov 9, 2006 | 01:02 PM
Propulsion's Avatar
Default Re: 1996 JDM H22a -- Auto or Manual Tensioner? (BB2H22)
what's the cost difference b/t replacing the auto tensioner vs. changing to a manual?
Old Nov 9, 2006 | 01:10 PM
98vtec's Avatar
moderator emeritus
a new auto tensioner itself is 70 dollars.
manual tensioner is about 50 dollars.
its going to come out to around the same price and an added insurance with the manual tensioner.
Old Nov 9, 2006 | 01:13 PM
Televator's Avatar
I sleep easy at night just knowing the motor I bought already came with the Manual Tensioner. Better safe than sorry I always say.
Old Nov 9, 2006 | 02:27 PM
Pilky's Avatar
Default Re: 1996 JDM H22a -- Auto or Manual Tensioner? (Televator)
Question: If you bring your car to the dealer for timing belt service they still use the auto tensioners correct?
Old Nov 9, 2006 | 02:35 PM
98vtec's Avatar
moderator emeritus
Default Re: 1996 JDM H22a -- Auto or Manual Tensioner? (Pilky)
yes
Old Nov 9, 2006 | 03:04 PM
Pilky's Avatar
Does Honda do the manual tensioner if you ask them?
Old Nov 9, 2006 | 04:08 PM
XRSLUDE's Avatar
Old Nov 9, 2006 | 04:09 PM
asdfsad's Avatar
No honda wont do the auto to manual tensioners.
Old Nov 9, 2006 | 04:36 PM
98vtec's Avatar
moderator emeritus
Default Re: 1996 JDM H22a -- Auto or Manual Tensioner? (asdfsad)
if you have a friend there or you have a cool dealership (and not one that tries to rip you off) they will. But 9/10 times they will not.
Old Nov 9, 2006 | 05:21 PM
BB2H22's Avatar
They wont because its covered under warranty and they wont risk not putting it back together with the same parts it came in with.
Old Nov 9, 2006 | 05:32 PM
pinecone's Avatar
Default Re: (BB2H22)
So the f22a1 has a manual tensioner? Does it swap easily to the h22a?
Old Nov 9, 2006 | 05:39 PM
98vtec's Avatar
moderator emeritus
Default Re: (pinecone)
its the same as the h23
Old Nov 9, 2006 | 06:00 PM
typeS's Avatar
Default Re: (98vtec)
Can someone clarify for me what the F22 has. I have a 1994, prelude S with F22. I have a ticking sound that isn't valves and I've been wondering if its around the timing belt. Thanks.
How is the manual tensioner adjusted too?
Old Nov 10, 2006 | 06:10 AM
BB2H22's Avatar
Default Re: (typeS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeS &raquo;</TD></TR><TR><TD CLASS="quote">Can someone clarify for me what the F22 has. I have a 1994, prelude S with F22. I have a ticking sound that isn't valves and I've been wondering if its around the timing belt. Thanks.
How is the manual tensioner adjusted too?</TD></TR></TABLE>
F22 = Manual tensioner. The ticking... I have no Idea what that is but its not the tensioner. The manual tensioner adjusts itself. Its very easy to do with the motor out of the car, a little more difficult with it in.
Old Nov 10, 2006 | 07:37 AM
typeS's Avatar
Is this something that I should be adjusting and if so how often? How do I adjust it? I've looked in the search but haven't found anything descriptive enough. Thanks.
Old Nov 10, 2006 | 01:10 PM
alterdcreations's Avatar
Default Re: (typeS)
http://www.montrealracing.com/...00284
very good walk thru and parts list
FrostyDC4
Acura NSX
19
Dec 5, 2005 08:04 PM
tuoniz
Oct 28, 2005 01:22 PM
abeaujuin
Jul 24, 2004 05:27 AM
Tad
20
Jun 5, 2004 01:11 PM
