H22A1 Can U Hone (Searched)
Old Nov 8, 2006 | 09:12 PM
doubledeucehatch's Avatar
Default H22A1 Can U Hone (Searched)
I looked but the only info I could find was on the 97-2001 H22A1 but what about pre 97 and can u hone them.
Old Nov 8, 2006 | 09:22 PM
CGags13's Avatar
Default Re: H22A1 Can U Hone (prelude252)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude252 &raquo;</TD></TR><TR><TD CLASS="quote">I looked but the only info I could find was on the 97-2001 H22A1 but what about pre 97 and can u hone them. </TD></TR></TABLE>
rephrase pleeeese..do you mean bore out if so then you should have searched / checked faq
but i will explain shortly...if you mean bore..then yes but only using stock overbore or mahle pistons because of frm cylinder walls..also the machine shop has to be equipped to bore out frm cylinders...its often more trouble than its worth if youre trying to get performance gains...if you're trying to rescue a block than it might be a different story..but by then you mine-as-well buy a slightly used longblock
Old Nov 9, 2006 | 06:02 AM
I did search all the stuff I found pertained to 97 and up saying that they are frm but never heard or found anything for pre 97 and I want to polish the cylinder.
Old Nov 9, 2006 | 08:29 AM
94Vtecluder's Avatar
Default Re: (prelude252)
Search for 2point6. He at first had a 2.6l built H22 then it blew and is now running a 2.44l reliably daily driven.
Old Nov 9, 2006 | 08:49 AM
Thanks
Tommy Law
Feb 18, 2019 10:52 PM
Jake Pwns Hard
Jul 30, 2009 01:32 AM
99hondacura
Aug 21, 2008 08:05 AM
TypeRguy97
Sep 22, 2006 12:25 PM
