EM1 Bumper Removal/Headlight Install
I'm not sure if anyone can get to this tonight, but I've gotten a set of black housing headlights tonight and I'm going to go try put them in. I lost my Chilton's somewhere in the house lol If anyone has some bolt locations for me, I'd appreciate it.
Thanks
-Rafe
Thanks
-Rafe
pretty easy... i might miss some cause i didn't bother putting on some but here is a rough idea...
one on each side top of the fender liner 8mm bolt... then two 10mm on the bottom if u still have your bottom splash guard thing... its more in the middle... and like 4 screws on the bottom...(i don't rmb cause i never put it back on since i took off the bumper first time) and then 6 clips on top, 4 holds the grill and 2 hold the bumper... but u gotta take the 4 from the grill too its attached to your bump... should take less than 10 minutes... or less...
then headlights... two on top... one on each side... and to make it easlier remove the metal piece infront of the headlight... its held by two bolts.. and goes in one way...
have fun..
have fun..
its pretty much cake
first there are one bolt in each of the wheel wells
then take off your grill and the two screw holding your bumper from the top
then there is one or two bolts directly under the bumper right under the grill
then after that the bumper should come off
next the lights there are two bolts on top
then one connected on the inside of the fenders
then one on the inside of the radiator support
then two holding the headlight brckets at the botoom of the lights after that they should come out
just unplug the headlights and the blinkers and replace with the new lights
would u happen to be sellin your old lights
I may be, it depends on how much I get for them, I have a 1991 CRX Si that I'm thinking about converting to EM Headlights.
I just got everything finished about 20 minutes ago, I'll post pictures once I get them uploaded. Thanks for the info!
Jurassic Four
13
Jun 4, 2004 03:14 PM
