Rear Wing Removal
Old May 7, 2002 | 11:43 AM
JDM_Type-R's Avatar
Default Rear Wing Removal
I have done several searches but came up with no luck. I was just wondering, for those of you have know or have actually tooken off your rear wing, does it leave holes in the trunk? If so, are there ways to get rid of it? And once those holes are gone, is it possible to put the wing back on in the future? Any info appreciated. Thanks.
Old May 7, 2002 | 11:44 AM
AllMotorITR's Avatar
New User
Default Re: Rear Wing Removal (JDM_Type-R)
Yes, there are holes in the trunk after you remove the wing. No, if you fill those holes, the wing cannot be placed back on the trunk lid. You can get caps to place in the holes as a temporary fix, that way if you wanna put the wing back on you can.
Back in Black's Avatar
Rather OG
Yes, it leaves holes, yet no water will leak into the trunk.
Yes, you can plug the holes.
Yes, you can put it back on.
AssPenny's Avatar
only way to get rid of the holes is to get them filled by a body shop. Then to put the fin back on, you have to redrill the holes. Just plug the holes with plugs (dunno where to get them, call Mike K) and be done with it. That way if you wana put the fin back on, simply remove plugs, and bolt it back on.
Craig - Who is going to put the fin back on when he gets to expo
Old May 7, 2002 | 11:46 AM
Ausmith's Avatar
The wing uses double sided tape and 4 mounting bolts. Yes, there will be 4 small hole in the hatch deck.
If you want to reinstall a wing in the future, just cover the holes with vinyl or rubber grommets.
If you have the holes filled (approx $500 at a body shop) you have to re-drill them if you want to reinstall the wing.
Clayton - who just realized he can't type as fast as the rest of these *****
[Modified by Ausmith, 8:47 PM 5/7/2002]
Old May 7, 2002 | 11:47 AM
Willard's Avatar
Default Re: Rear Wing Removal (AssPenny)
Civic (92-95) plugs from the shock towers where a strut brace would mount (if it came with one)... work just fine for me.
Willis
Old May 7, 2002 | 12:01 PM
JDM_Type-R's Avatar
Default Re: Rear Wing Removal (Willard)
Out of all methods of covering up the holes, which one is least noticable, and less expensive? Anyone have pics of those plugs you guys are talking about? Thanks.
Old May 7, 2002 | 12:03 PM
Rather OG
Depends on the color of your car. Plastic caps from Autozone worked fine for me, yet they are black...
Old May 7, 2002 | 12:07 PM
SurferX's Avatar
Default Re: Rear Wing Removal (Vader in NC)
For black or white you could make the plugs pretty inconspicuous easily. For yellow I'd just paint the plugs with touch up paint.
Old May 7, 2002 | 12:09 PM
Rob :190:'s Avatar
Default Re: Rear Wing Removal (SurferX)
Wingless 0wnZ!!!
Old May 7, 2002 | 01:09 PM
98itR484's Avatar
Default Re: Rear Wing Removal (Brian Spilner 1035)
my question a little off topic, but how do you get the wing off of the double sided tape????
Old May 7, 2002 | 01:15 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: Rear Wing Removal (98itR484)
Dental Floss.
Old May 7, 2002 | 01:18 PM
ASR's Avatar
ASR
New User
Default Re: Rear Wing Removal (ActiveAero)
I took mine to the body shop and had them filled and the painted blended over, you can't tell the wing was ever there! It looks great but you will now not only have to explain that you car doesn't have NOS but also that yes it is a real type r you just took the wing off!
Old May 7, 2002 | 01:19 PM
Ross's Avatar
25 Year Member
Community Builder
Active Streak: 30 Days
Default Re: Rear Wing Removal (ASR)
...and sold it to some kid wrapped in a J. Crew sweater!
Old May 7, 2002 | 01:25 PM
98itR484's Avatar
Dental Floss.
are you serious???? I'll have to try that when i get home from school today. Then how do you go about getting all the tape off of the car safely??? sorry for all the questions..thanks
Old May 7, 2002 | 01:33 PM
IntegraT's Avatar
If you do remove your wing, beware, there is a very good chance you will lose control of your vehicle due to the reduction of downforce.
Old May 7, 2002 | 02:32 PM
ASR's Avatar
ASR
New User
Default Re: Rear Wing Removal (Ross)
Yeah I did wrap it in a sweater, it was going to goodwill anyway so I figured it would make good packing material!
Old May 8, 2002 | 02:58 PM
JDM_Type-R's Avatar
So where do I want to find these plugs that u guys are talking about? Approx. how much $? let me know. Thanks.
Old May 9, 2002 | 04:48 AM
ASR's Avatar
ASR
New User
You can find these plugs at any sex shop, oh wait I think you're asking about the other plugs we're always talking about, in that case I don't know!
Old May 9, 2002 | 04:51 AM
Willard's Avatar
from above...
Honda dealer will have what you are looking for.
Willis
Old May 9, 2002 | 05:27 AM
Dr Pooface's Avatar
Part # for the plugs are 91601-SR3-000 or 003, I forget which.
Old May 9, 2002 | 05:28 AM
Dr Pooface's Avatar
You can just rub the rest of the tape off with your fingers, its easy.
Old Jun 19, 2002 | 02:22 PM
Junglist's Avatar
Default Re: Rear Wing Removal (Ddub)
it's 91601-SR3-000
Old Jun 19, 2002 | 02:29 PM
RTW DC2R's Avatar
Default Re: Rear Wing Removal (Junglist)
if you remove the wing, make sure to replace it with a triple decker picnic table aluminum wing thats so heavy it makes your hatch sag!!!!
no the real note though, i like winged and wingless
Old Jun 19, 2002 | 03:24 PM
Chris_R's Avatar
Default Re: Rear Wing Removal (RTW DC2)
What a conicidence this post gets ressurected. I just took my wing off today! And I love it.
