Injectors, what kind??
Well for superchargers most people use the rc 750's or the rc 550's. Mostly its the 550's in the turbo setups. You adjust your fuel pressure with an adjustable fuel pressure regualtor.
The size of the injector depends on your setup and how much air is being ingested by the motor?I personally run 1000cc but depending on you setup and how much power you are trying to make will determine the size.The fuel pressure can be adjusted with a fuel pressure regulator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by panchovilla760 »</TD></TR><TR><TD CLASS="quote">how can you tell what kind of injectors you have?? all i know is that they are red top. also how can you adjust your fuel pressure??</TD></TR></TABLE>
Most injectors have some sort of labeling or part # on them. Pulling them off a factory car though good luck identifying exactly what they are.
Get an adjustable fuel pressure regulator (typically 1:1 for boosted cars)
C_I_V_I_C_V_T_E_C
Aug 19, 2007 09:31 PM
Djbower1
Dec 27, 2005 02:56 AM
