Master cylinder/brake lines
Old Nov 8, 2006 | 04:30 PM
RockWolf's Avatar
Default Master cylinder/brake lines
After this winter I will change the master cylinder including most( not to say all) of the brake lines( inside as outside) I just would like to know if there is a H-T sponser that sell that or what site should i go to get good quality prices other then egay.
Thx
Old Nov 8, 2006 | 04:48 PM
Targa250R's Avatar
be professional
Default Re: Master cylinder/brake lines (RockWolf)
Why? Is your master cylinder failing?
Why are you replacing "most of the brake lines"?
I'd personally either buy the lines pre-bent from Honda - or pick up a bender, flaring tool, and some hydraulic lines and fittings and make my own.
Old Nov 8, 2006 | 04:57 PM
Crx Jimmy's Avatar
most of the lines run inside the car and arent in the elements and dont rust. why do you want to replace them?
Old Nov 9, 2006 | 06:01 AM
RockWolf's Avatar
Default Re: Master cylinder/brake lines (Crx Jimmy)
there is rust on some of the internal brake lines... its because during winter you wear boots right? to help melt ice we put salt..... since i drive manual i need to press the clutch and when i am not pressing the clutch i put my foot on the left side. Then the carpet gets wet of the salt water mixture... what do you think is under that side hun? most of the metal lines which rust a little by little.
also it seems that the previous owner droped some brake oil next to the master cylinder lines and never cleaned them. guess what is happening.
and yes my mastercylinder is starting to fail on me i need to push more and more to get the same braking power as my dads si which has a clean braking system.
Old Nov 9, 2006 | 08:16 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockWolf &raquo;</TD></TR><TR><TD CLASS="quote">there is rust on some of the internal brake lines... its because during winter you wear boots right? to help melt ice we put salt..... since i drive manual i need to press the clutch and when i am not pressing the clutch i put my foot on the left side. Then the carpet gets wet of the salt water mixture... what do you think is under that side hun? most of the metal lines which rust a little by little.</TD></TR></TABLE>
Just because there is some surface rust on the lines doesn't mean you need to replace them all. How badly are they rusted?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">also it seems that the previous owner droped some brake oil next to the master cylinder lines and never cleaned them. guess what is happening.</TD></TR></TABLE>
Brake fluid removes paint. I don't see what that has to do with replacing brake lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and yes my mastercylinder is starting to fail on me i need to push more and more to get the same braking power as my dads si which has a clean braking system.</TD></TR></TABLE>
That doesn't mean the MC is failing. If you still have consistent pedal feel and the pedal does not sink while stopped, your MC is good.
If you have to push increasingly harder on the pedal to get the same braking power, either the coefficient of friction between your pads and rotors is down (possibly glazed pads, worn out pads, glazed rotors), or your hydraulic system need to be bled (possibly air in lines, boiled fluid).
crxguy1991
Mar 25, 2012 11:36 AM
TopEndUSA
Feb 22, 2009 04:10 PM
uses0ap
Sep 21, 2008 08:19 PM
gophat
Dec 26, 2006 05:53 PM
DIYaccord
Apr 1, 2004 07:07 PM
