H23 T-belt tensioner on H22
Old Nov 8, 2006 | 03:32 PM
h22sedan's Avatar
Default H23 T-belt tensioner on H22
Does anyone know the necessary parts to convert a H22A from auto-tensioner timing belt to a H23 manual tensioner?
I've tried searching for this but I'm not having much luck.
Old Nov 8, 2006 | 03:35 PM
alterdcreations's Avatar
Default Re: H23 T-belt tensioner on H22 (h22sedan)
majestichonda.com
Old Nov 8, 2006 | 03:41 PM
Revi's Avatar
Default Re: H23 T-belt tensioner on H22 (alterdcreations)
13404-PT0-004 - ADJUSTER COMP., BALANCER BELT
13415-PT0-000 - BRACKET, BALANCER BELT ADJUSTER
14510-PT0-004 - ADJUSTER COMP., TIMING BELT
14516-PT2-000 - SPRING COMP., TIMING BELT ADJUSTER
14521-P14-A00 - PLATE, ADJUSTER
90014-P14-A00 - BOLT, TIMING BELT ADJUSTER BASE
90015-PT0-000 - BOLT, TIMING BELT ADJUSTER SPRING
90016-PT0-000 - BOLT, TIMING BELT ADJUSTER
90140-P14-A00 - WASHER, PLAIN (11MM)
Old Nov 8, 2006 | 03:45 PM
h22sedan's Avatar
Damn, this dude's on point. Thanks. This should be a direct bolt-on conversion, correct?
Old Nov 8, 2006 | 04:19 PM
Rosko's Avatar
Default Re: (h22sedan)
there is a thread in the FAQ's that tells all about it. The pictures at the begining don't work, but they were reposted later in the thread.
Old Nov 8, 2006 | 05:20 PM
wle05's Avatar
Default Re:
Or check out http://www.collectiveracing.net
CivicB18C1
Jun 15, 2013 01:31 PM
24
Dec 21, 2005 01:23 AM
h8trix
Aug 11, 2005 08:36 AM
93LudeVtec
Feb 3, 2003 06:15 PM
SilverEk3dr
Jan 29, 2003 11:27 AM
