rsx cluster swap
Old Nov 8, 2006 | 02:54 PM
SIBuddy's Avatar
Default rsx cluster swap
i have a 2000 GSR and i want to put a rsx cluster in but i want to see pix of one already done before i do it so if any one has pix post up thanks
Old Nov 9, 2006 | 12:47 PM
autosport7's Avatar
Default Re: rsx cluster swap (SIBuddy)
I have a cluster if you need it some other int parts
Old Nov 30, 2006 | 12:46 PM
WARCOVENANT's Avatar
you cant do it unless you have the k20 ecu. in other words, youll have to be swapped to make it work. then youll have to use an entire dash harness from a rsx.
i did the k20 swap and so i looked into the cluster swap a while back.. but never bothered.
Old Nov 30, 2006 | 01:20 PM
Race Egr's Avatar
Default Re: rsx cluster swap (The Dude)
Well how can a k20 swap work with a stock integra cluster then?
Old Nov 30, 2006 | 07:22 PM
H22a1civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Dude &raquo;</TD></TR><TR><TD CLASS="quote">you cant do it unless you have the k20 ecu. in other words, youll have to be swapped to make it work. then youll have to use an entire dash harness from a rsx.
i did the k20 swap and so i looked into the cluster swap a while back.. but never bothered. </TD></TR></TABLE>
Thats not true at all. That like saying you a F20C (S2000) motor to run the S2000 cluster in a eg. I have seen it done before in a eg but never in a dc. It can be done, your just going to have to repin everything to the correct pins out in your ecu. Just search the forms for it.
Old Nov 30, 2006 | 08:08 PM
thermal's Avatar
Nope.... not directly anyway. It is more than just picking out the ECU pins. I've searched this before. The signals are different. Has to do with analog values. However, this is Honda-Tech. Somebody had done some electronic conversions before.
Old Dec 1, 2006 | 10:45 AM
H22a1civic's Avatar
Default Re: (thermal)
Best info I was able to find
https://honda-tech.com/zero...00225
Old Dec 1, 2006 | 01:29 PM
TehLonz's Avatar
Default Re: (H22a1civic)
time to rip @ the wiring diagrams.
DWOL
Dec 24, 2010 12:56 PM
es202
Honda Civic (2001 - 2005)
Nov 3, 2010 08:28 PM
integra_ls_2dr
19
Jan 5, 2010 06:25 PM
Nbboy7
13
Jan 7, 2007 08:34 AM
. o 69 o .
Jan 9, 2005 09:49 PM
