Problems engaging clutch- loss of clutch fluid
Hi guys,
WOnder if you can help. The gears on my car are really difficult to select, this being due to the clutch now having such a low biting point. THere is alot of excess travel in the clutch.
I believe there to be some air in the sytem- I checked the clutch fluid level and it had fallen well below minimum.
I have topped it up with clutch fluid, but i am face with two problems which i need your help with;
1. How do i bleed the clutch sytem?
2. How to I identify where the leak is occuring?
Many thanks in advance,
Mike.
Mike.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC-LUDE »</TD></TR><TR><TD CLASS="quote">BUMP</TD></TR></TABLE>
look under the clutch pedal, they often lek right there onto the driver's floorpan
hondapwr
19
Dec 21, 2007 06:16 PM
Buckshot
Nov 17, 2002 08:43 PM
