Searched but found nothing, water puddle in passenger side??
I have had a persistent problem with leaking in the passenger side of my crx, after a night of rain a puddle has acumulated behind the seat in the carpet area. I thought it was from the windshield since i had it replaced but i had it taken out and resealed and OEM gasket put back on, still leaks, any where else it could be leaking from?
check the seals around the side windows and also the door.
you also might want to check your trunk area, around the spare, and make sure now water is getting in from the rear
I had the same problem but my passenger window wasnt sealing. You shouldve already taken care of that with the new window and gasket.
Something I noted was in your sig it shows you have a Si model? There are drain tubes or something that I always hear people say you need to check make sure they arent clogged. They are for the sunroof.
I had the same problem, I took the carpet out and dried the passenger side floor. Stayed inside and had my Pops pour some water on the car while I was inside. Turns out it was leaking from under the dash area. I used some silicone and sealed the part where the windshield meets the car/plastic. Hasn't leaked since.
My car leaks but it was hit so i think thats most of the problem but where the AC went through the firewall was where it was leaking..I had nothing there since I don't have AC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">I had the same problem, I took the carpet out and dried the passenger side floor. Stayed inside and had my Pops pour some water on the car while I was inside. Turns out it was leaking from under the dash area. I used some silicone and sealed the part where the windshield meets the car/plastic. Hasn't leaked since. </TD></TR></TABLE>
i actually think this mgiht be my problem too i can see from the dash its wet then it flows back. did you mean the plastic on the outside by the wipers?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iphatcrxi »</TD></TR><TR><TD CLASS="quote">
i actually think this mgiht be my problem too i can see from the dash its wet then it flows back. did you mean the plastic on the outside by the wipers?</TD></TR></TABLE>
Yes, that is the piece I took off. I am not sure what it is called.
I have that same problem. It's either the rear taillight gaskets leaking and the water is traveling all the way up there, or it's a crack underneath the frame of the car.
Posted from Honda-tech.com App for Android
The rest of the thread is 2006 as well.
This thread died in 2006.
(No idea no care about the last activity 1969... lets just say he's not active anymore.)
mikecp
15
Aug 22, 2010 07:56 AM
92EGMINIME
Apr 8, 2009 12:34 AM
