halo headlights
i just got these headlights http://cgi.ebay.com/ebaymotors...wItem
for my 99 accord coupe. as you can see in the picture there are 2 empty spots on back of the lights twards the outside covered by stickers. what goes in these spots? does it come off my stock lights? please help me!!!! thank you all so mutch~mike
i did a search and could not find a post on this topic.
if there is one can you please direct me to it and if not can you tell me how to install the parking light and turn signal~thanks, mike
My bad man, you pretty much posted exactly what someone else did like three posts up. You should read through the recent posts before making a new one exactly the same like 2 hours later.
on 5th gens you have to take off the bumper support. theres like 4 or 5 bolts holding the actual headlight on. once you have the old one off the new one goes back exactly the same way. plug in the new bulbs/harnesses(if you got some) then put the bumper back on. high beam is inside, then low beam, then parking light, then signal. wiring up your halo lights you can do a few different ways but its easiest just to splice them into the parking lights.
it should come with new high and low beam bulbs.. mine came with an adapter to plug into the old harness because the new lights had H1 bulbs. the parking lights and corner flashers you can strait transfer from one to the other.
katb16vo
Apr 7, 2004 11:37 AM
That's why I did'nt get a set...
