Stock rim switch to 15" rims, question.
Old Nov 7, 2006 | 09:13 PM
Steven.'s Avatar
Default Stock rim switch to 15" rims, question.
The stock rims on a 93 dx are how big? 14" or less?
If i use 15" rims with the same size tires will everything work okay speedometer etc?
Old Nov 7, 2006 | 09:17 PM
sol2hatch's Avatar
Default Re: Stock rim switch to 15" rims, question. (Steven.)
everything will be fine. your speedo might be off, but not by a noticable amount. If you get the right profile tires, then your diameter will actually be the same as with the 14s
Old Nov 7, 2006 | 09:20 PM
Steven.'s Avatar
bigger tires = loose hp tho?
Old Nov 7, 2006 | 09:34 PM
sol2hatch's Avatar
Default Re: (Steven.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steven. &raquo;</TD></TR><TR><TD CLASS="quote">bigger tires = loose hp tho?</TD></TR></TABLE>
no. As I said before, if you get 15 inch rims with lower profile tires, then the tire will be the same size around as your 14s were, thus, no change, except if your 15s are way heavier than your 14s, which they are probably not.
Old Nov 8, 2006 | 12:27 AM
M2nR's Avatar
Default Re: (sol2hatch)
Arnt the DX steelies 13's"??
Old Nov 8, 2006 | 12:52 AM
Steven.'s Avatar
Default Re: (M2nR22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2nR22 &raquo;</TD></TR><TR><TD CLASS="quote">Arnt the DX steelies 13's"??</TD></TR></TABLE>
So would what the appropiate size tire with 15" rims be..?
Old Nov 8, 2006 | 02:09 AM
t0p_sh0tta's Avatar
For 92-95, the correct size would be 195/50/15.
Old Nov 8, 2006 | 02:20 AM
M2nR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">For 92-95, the correct size would be 195/50/15.</TD></TR></TABLE>
That is correct
Integra Girl
May 23, 2007 07:29 PM
vtec25
Feb 10, 2007 09:37 PM
1995Civiccx
Jan 16, 2007 04:20 PM
latinf86
23
Sep 12, 2006 09:10 PM
Acc91ord
May 3, 2004 09:04 AM
