My crx 1st time at the strip...
89 si pretty much gutted...
b18a1 250k
t25 8 psi
dsm 450s
dsm 1gbov
jdm J1 tranny
te
shitty home made traction bar so i spin 1st and 2nd
bfg's @ 30 psi (had to drive home)
ran a 14.59@96...
completely un tuned
the j1 has such short gears, i have rev limiter set to 6750 and still runs out of gear before the stripe...
anything i can do?
b18a1 250k
t25 8 psi
dsm 450s
dsm 1gbov
jdm J1 tranny
te
ran a 14.59@96...
completely un tuned
anything i can do?
more revs and bigger tires will get u more speed u need. So ur at the top of 4th in the 1/4 or 5th?
the 6750 rev limiter probably isnt a bad thing for the LS since its not making power up their. Mabey get a cable LS tranny. the gears arnt too long when u have a decent power.
thanks for the replies. the thing tops out at 6750 in 5th gear.
yes spinning out of the hole and all the way thru 2nd.
i dont feel like changing trannys again yet.
so taller tire and more revs huh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls_dx »</TD></TR><TR><TD CLASS="quote">long story had to use the j1 trans instead of my ls trans. what trans are the big turbo guys running ?? hydro gsr?</TD></TR></TABLE> I used a Ys1 LS tranny reving to 8,000 and traping at 121 i was at the end of 4th gear on 23" slicks
thats all you can really do i mean slicks maybe umm light the car up cant relly do to much with a block that has 250k mi. umm maybe try to get a block with less miles and tune the motor im sure with a tune and slicks light the car up a bit you can see some mid 13's (depend's on how you drive)
ivan93egreppin210
May 19, 2008 11:47 AM
SiCRX90
Dec 1, 2006 04:11 AM
civicdragger818
44
Aug 6, 2005 06:25 PM
