calling all ac gurus
Old Nov 7, 2006 | 08:09 PM
justseeingifitistaken's Avatar
Default calling all ac gurus
I just bought my wife a crx, 90 dx, and someone took the time to change over from r12 to r134a. The problem is it had no charge at all when i recieved it. So today i got the r134a and the gauge to check it out. it had lieki 12psi so brought it up to 45 psi and it stays fine but i cant considerably notice a change in the way it cools. the wife is getting on me about it so i need to figure it out. should these systems be brought higher than 45?? that is waht the guy at the local ac shop told me. anyway thanks
Old Nov 7, 2006 | 08:10 PM
Default Re: calling all ac gurus (hondaJDMimports)
BTW the compressor is from a 95 i believe, nothing like all the other compressors i have seen. thanks
Old Nov 8, 2006 | 05:36 AM
civicandy's Avatar
i have a complete a/c system from a crx and civic if you need any parts. i'd check with a honda dealer for the recomended psi for the system before you go any higher.
Old Nov 8, 2006 | 05:39 AM
Timmah!!'s Avatar
Default Re: calling all ac gurus (civicandy)
Did you vacuum out the system before refilling it?
Old Nov 8, 2006 | 05:42 AM
crawfo661's Avatar
Default Re: calling all ac gurus (Cobra Tim)
drain the system and refill it, can you hear or see the compressor actually spool, and are you filling and checking the pressure with the ac on max?
Old Nov 8, 2006 | 08:37 AM
wiZCo's Avatar
Stouts 'n' Scotch
Did you replace the expansion valve when you did the conversion?
Old Nov 8, 2006 | 08:59 AM
Default Re: (wiZCo)
To answer everyones questions:
1. i did not vacuum out the system before refilling it because it is already r-134a and it already had a charge just a low one, i just recharged it.
2. the compressor is 'spooling' if that is waht you call it when the clutch kicks and it starts putting some drag on the motor. I do have air just not the coldest. I live in Hawaii so it is still semi warm outside and my a/c doesn't feel that great that is why i recharged it. oh and it is on max, but doest seem to want to pull anymore out of the can. it is still mostly full???
3. I did not replace the expansion valve because it was already converted before i got it, but where is the expansion valve? i am doing the conversion on my other rex right now and need to make sure i am doing it right, but i never heard about replacing the expansion valve.
Well thanks for all the quick responses guys. this is what i love about h-t
Old Nov 8, 2006 | 09:01 AM
whiteknightef's Avatar
Default Re: (wiZCo)
also 134 is not as cold than r12
Old Nov 8, 2006 | 09:05 AM
wiZCo's Avatar
Stouts 'n' Scotch
Just because the system was converted to R134a doesn't neccessarily mean the expansion valve was changed. The expansion valve is the same no matter which coolant you use, it's just specific to our vehicles. You can find it in the evaporator case under your dash. I'd try changing it out and vaccuuming out your system while you have it empty (just in case).
Old Nov 8, 2006 | 09:10 AM
Default Re: (wiZCo)
is the expansion valve the same as an orifice tube??? if so could that be culprit of a clogged system??? my other rex wont take a charge and an a/c guy said it could be the orifice tube but didnt tell me jack about it. i need to check it out.
thom21
Aug 15, 2017 06:49 AM
cbrman
23
Jun 23, 2009 11:15 AM
M@
Mar 31, 2007 10:14 AM
Trey
Jul 14, 2003 08:58 AM
KooK
May 21, 2003 04:30 PM
