swap or fix?
Old Nov 7, 2006 | 06:06 PM
EFsauce's Avatar
Default swap or fix?
I recently bought a 91 EF9 si and it started having problems.. so i checked it out and found out that, first of all, it was a sohc ZC motor .. and the problem is that the cam/crank seals leak oil.. alot of oil.
So my question is.. should i go ahead and spend money to fix the leaks? or just drive it with the leaks untill i decide to swap it (b16)? the motor is said to have 135k miles. swap or fix?
Old Nov 7, 2006 | 06:36 PM
DC_RaceR's Avatar
Default Re: swap or fix? (EFsauce)
Depend how deep is your pockets.
And how good are you replacing the rear crank seal.
If you do it yourself then I would say fix it.
If not then I would say swap...
Because the shop is going to charge you a lot of money..
Alex V
May 15, 2018 08:25 AM
GRANDE7652
Jul 31, 2006 01:55 PM
Thrillhouse
May 15, 2005 10:13 PM
anjapower
Feb 11, 2004 07:59 PM
Toxic H
May 8, 2003 08:04 AM
