for those who use one of those v-tech controllers .....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt067 »</TD></TR><TR><TD CLASS="quote">v-tech makes phones and kids toys what are you talking about?</TD></TR></TABLE>
LOL
but I had mines at about 4000
LOL
You shouldnt play with your vtec engagement unless on a dyno with some sort of fuel management.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er »</TD></TR><TR><TD CLASS="quote">
LOL
but I had mines at about 4000</TD></TR></TABLE>
4000 is way to low. there is a reason vtec comes on at 5000+. Use your low cam
LOL
so everyone has a V-tech phone in their cars? amazing i should get one of those! fyi it's vtec
if you want to use a controler on a stock block(or near stock for that matter) be my guest. it's your money and your gas. I will never use one. it's more for bling bling more than anything else
True Dat HonDelso!
My b16a came with a chipped ecu. My VTEC engages around 43-4400rpms and it doesn't really start to pull hard until around 53-5500rpms. I think it would be a little stronger if tuned back to stock.
My friend is running ls/vtec in an eg hatch with a controller and we went out and played with it and it definately hurts performance to lower it much at all unless you have cams that are made for that.
Run it from stock ecu if possible. Controllers are just handy if you don't want to change ecu's on something like a mini-me swap or ls/vtec.
on my old setup, i infact tuned the vtec controller on a dyno.
final set was at 5900 rpms. low cam had no problem reving it up that high, when vtec kicked in, it literally 'kicked'. wasnt just noise.
