swap AND motor MOUNT question
Old Nov 7, 2006 | 01:25 PM
NSfit's Avatar
Default swap AND motor MOUNT question
alright so im doing a swap on my eg. d series to b series. i have the new motor mounts but do i have to put these mounts back in?
Old Nov 7, 2006 | 01:48 PM
crashzerothree's Avatar
Default Re: swap AND motor MOUNT question (NScivic)
Those are torque mounts and I would put them back in, unless all of your mounts are badass like some HASPORTs, cuz your motor might pop up and hit your hood, and they arent too hard to install so you should just do it anyways. better response with a stiffer motor
Haha nice quote NScivic-
"if i fill half' my tank with Shell V-Power gas, and the other half with Chevron with Techron will i have V-TEC gas?"
Old Nov 7, 2006 | 01:50 PM
NSfit's Avatar
Default Re: swap AND motor MOUNT question (crashzerothree)
yeah i have innovative mounts they are pretty nice. will the d series mounts bolt on to the gsr block?
Old Nov 7, 2006 | 01:56 PM
NSfit's Avatar
ok just tried fitting them and they don't fit... what kind of HP numbers are we talking about where it is mandatory for me to have them
I am pretty sure that D-series torque mounts would NOT work, i think they bolt up to the block but they do not line up with the rubber mount on the frame. But dont take my word, i am not completely positive.
Old Nov 7, 2006 | 01:59 PM
well you said you have some stiff mounts so i guess i wouldnt worry about it to much. People have told me that if you get all three hasport mounts then you do not need the torque mounts anymore. but i cant speak for other brands
Old Nov 7, 2006 | 02:00 PM
B18C5-EH2's Avatar
Former Moderator
Loved
The mounting brackets from your D series won't bolt to the B series block nor tranny, but I'd keep those mounts personally.
You'll need to B series front tranny bracket that the right mount slides onto, and depending on whether you've got power steering and/or A/C that will determine which A/C bracket you'll need to bolt to the block to employ the left side mount.
If you have no A/C and no P/S then you can use the stock B series bracket that bolts to the block where an A/c comp would usually bolt to the bracket, but if you have A/C, but no P/S use a 1997 CR-V bracket there, and if you have A/C and P/S use a 1994 Del Sol VTEC (the one with a stock B16A3 engine) there.
KEEP the actual Civic rubber pieces in your pics though, because Integra ones do not sit flush on the under side of your frame rails.
This is gosphel truth from experience.
sseo89
Jul 14, 2017 12:06 PM
ramboPandA
Jul 17, 2014 12:35 PM
1994delsolLS
Nov 7, 2008 06:00 PM
b18 EK9
Mar 30, 2006 10:30 AM
ForceFed Coupe
Dec 13, 2003 04:19 PM
