Crx swapping info needed.
Old Nov 7, 2006 | 08:58 AM
Shaun_'s Avatar
Default Crx swapping info needed.
I have a 91' crx hf. I have a whole da integra car for parts.
The only thing i have done is the rear brake swap.
What all do i have to do to take the b18a motor and put it in my crx?
Mounts? Can i use the integra mounts?
Harness? The plugs look the same but are the pins the same?
I would like a parts list of the basic stuff
Radiator hose - from what car will fit.
Axles
mounts
ecu
I searched but couldnt find.
Old Nov 7, 2006 | 09:13 AM
russianswty's Avatar
Default Re: Crx swapping info needed. (Napoleon)
Do plunty of searching theres so much info on this
But if its cable then you can use that tranny with the engine.
Get the wiring harness for the clips and sensors, or you could
always get the wiring kit from rywire or something. You need
special mounts, differant linkages. Different ecu.
Different headers, integra stock cv halfshafts, with the mid shaft.
Oh and you have to modify your frame a little,
thats all I can think of off top of my head but thers probably more.
Old Nov 7, 2006 | 09:19 AM
Shaun_'s Avatar
Yeah i know about denting the fram rail a bit. I know the trans will work and all of that.
I read that when using the integra axles you have to take off the dust ring off the bearing or something? I am going to modify the linkage from the integra.
Motor mounts?
Old Nov 8, 2006 | 08:48 AM
Default Re: (Napoleon)
HASPORT mounts, the best ones. If your using the cable tranny use the EFB1 kit they offer. And I think its just easier to get the right linkage instead of modifying it, unless you know exactly how much it needs to be modifying.
But I never heard anything about removing the dust caps, but if you find out that
you do, go ahead and post it, since im in the middle on my swap right now.
91c-rex_si
14
Mar 27, 2011 08:07 PM
super china china
Apr 19, 2007 01:42 PM
JLefevers
Mar 29, 2006 10:18 PM
ransack
30
May 10, 2004 06:39 PM
88crx Osaka
May 18, 2003 10:11 AM
