JDM EK Sidemarkers, am I missing a wire?
Old Nov 6, 2006 | 07:29 PM
92integraVTECgsr's Avatar
Default JDM EK Sidemarkers, am I missing a wire?
the one on the right has 3 wires. the one on the left has 2 wires. Is there supposed to be 3 on each?
Old Nov 6, 2006 | 07:30 PM
dohcVTECeg2's Avatar
Default Re: JDM EK Sidemarkers, am I missing a wire? (92integraVTECgsr)
mine just came with 2 wires. power and ground
Old Nov 6, 2006 | 07:58 PM
usdmEHboy's Avatar
Default Re: JDM EK Sidemarkers, am I missing a wire? (dohcVTECeg2)
yea my eg ones only have power and ground also
Old Nov 6, 2006 | 08:39 PM
oneup's Avatar
Default Re: JDM EK Sidemarkers, am I missing a wire? (usdmEHboy)
My Passwordjdm harness only came with two aswell.
Old Nov 6, 2006 | 09:43 PM
Jagolas's Avatar
Default Re: JDM EK Sidemarkers, am I missing a wire? (oneup)
my ek sides came the same way. Just cut the blue one, they will still work perfectly. I think the third wire is for the passenger side to blink and still stay lit up (i think it's the pass side with the extra wire can't remember).
Old Nov 6, 2006 | 09:47 PM
BlueIntegraBoy's Avatar
When you wire, connect the two green wires together.
Old Nov 6, 2006 | 09:51 PM
di2ferio's Avatar
Default Re: JDM EK Sidemarkers, am I missing a wire? (BlueIntegraBoy)
i have the same harness all i did was just wire the two wires and just cut the last wire...
Old Nov 6, 2006 | 10:54 PM
speedracervroom's Avatar
yeah mine are only two wires also
Old Nov 6, 2006 | 11:19 PM
turboekcivic's Avatar
Default Re: (speedracervroom)
i had that you just put that together its the same wire
Old Nov 7, 2006 | 09:57 AM
Default Re: (turboekcivic)
so with just the 2 wires, will they stay on when the lights are on and blink as well?
Old Nov 7, 2006 | 10:01 AM
Jagolas's Avatar
Default Re: (92integraVTECgsr)
search for the wiring instructions, right now mine only stay on, I haven't had time to wire them up to blink as well. I think you can either have them stay on or blink, you would have to wire up a relay or something to get them to do both.
Old Nov 7, 2006 | 10:16 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">so with just the 2 wires, will they stay on when the lights are on and blink as well?</TD></TR></TABLE>
Not if you wire them correctly.
Old Nov 7, 2006 | 10:22 AM
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Not if you wire them correctly. </TD></TR></TABLE>
thats what i thought.. i know ive seen people have them wired up to blink and stay on. I think that 3rd wire is the key.
Old Nov 7, 2006 | 10:41 AM
Padawan's Avatar
Darth ModerVader
thats what i thought.. i know ive seen people have them wired up to blink and stay on. I think that 3rd wire is the key.</TD></TR></TABLE>
Actually, these people usually just connect them to the positive turn signal wire and the positive parking light wire, rather than connecting them to the positive turn signal wire and an earth (which would be the correct way).
Old Nov 7, 2006 | 10:51 AM
im gonna add 1 wire to the turn signal, and the other to the parking light and the black to ground. I'll see if that works and how good it is.
Old Nov 7, 2006 | 10:55 AM
Padawan's Avatar
Darth ModerVader
Just wire them into the turn signal positive and ground. That's the way they are designed to function.
fcm
Aug 30, 2013 03:30 AM
claymonthug
Feb 14, 2010 06:17 PM
CivicMike
Jun 27, 2005 07:18 AM
silver hatch
Mar 29, 2005 01:52 PM
Chris y0!
Mar 22, 2003 08:30 PM
