tire pressure
Old Nov 6, 2006 | 06:53 PM
type B16's Avatar
Default tire pressure
winter time.
whats a good tire pressure to run for maximum traction and still be safe for the daily driver?
Old Nov 6, 2006 | 06:57 PM
Padawan's Avatar
Darth ModerVader
Default Re: tire pressure (type B16)
I'd just maintain the pressure you're currently running. Just remember to check and adjust as the weather changes, because temperature will affect tyre pressure (roughly 1 psi per 10 degrees).
Old Nov 6, 2006 | 07:33 PM
blub18's Avatar
30-32psi
Old Nov 6, 2006 | 07:34 PM
old man neri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type B16 &raquo;</TD></TR><TR><TD CLASS="quote">winter time.
whats a good tire pressure to run for maximum traction and still be safe for the daily driver?</TD></TR></TABLE>
Car manufacturer's recommended pressure which can be found either on the glove box or door jam or in the owner's manual. You can then adjust the pressure up or down 2psi at a time to suit you specific needs of handling, comfort, feel...etc.
For best winter traction get winter tires if you don't have them already.
Cheers.
Old Nov 6, 2006 | 07:41 PM
sql_civic's Avatar
Default Re: tire pressure (old man neri)
But be sure not to exceed the maximum pressure rating written on the side wall of the tire itself.
grpape
16
May 14, 2009 10:24 AM
RACEPAK
Jul 12, 2008 04:27 PM
nsxtasy
Sep 14, 2005 04:50 PM
mugen92acintls
Mar 6, 2004 02:12 PM
shadowdawn
Nov 5, 2002 11:21 AM
