rpm gauge is turning off randomly?
Old Nov 6, 2006 | 04:58 PM
l1bid0's Avatar
Default rpm gauge is turning off randomly?
Today when i was driving my rpm guage would turn off/ needle would flicker. Also when i start up sometimes it will have issues. Have anyone of you had this problem? Oh I drive a 90 hb si. Thanks
Old Nov 6, 2006 | 05:01 PM
HonDelso's Avatar
could be your dizzy. if you have trouble starting sometimes, and your rpm gauge is working/not working in spurts. the Dizzy is the only thing tied to both starting and your rpm gauge.
Old Nov 6, 2006 | 05:16 PM
Tyson's Avatar
Default Re: rpm gauge is turning off randomly? (l1bid0)
i agree, probably something in your distributor.
can never tell if its the coil or the ignitor. i always forget which is which, and what does what anyway...
i had the same problem for a while and i just replaced my distributor with another one i got off ebay or something and it went away.
Old Nov 6, 2006 | 05:30 PM
Rex-Si's Avatar
Default Re: (HonDelso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HonDelso &raquo;</TD></TR><TR><TD CLASS="quote"> the Dizzy is the only thing tied to both starting and your rpm gauge.</TD></TR></TABLE>
Old Nov 6, 2006 | 07:46 PM
l1bid0's Avatar
thanks i'll check it out.
Old Nov 6, 2006 | 11:43 PM
13g-crx's Avatar
Had the same problem and thought it was the distributor. Turned out to be a loose ground on the thermostat housing. Prolly the dist.
Old Nov 7, 2006 | 07:13 AM
wiZCo's Avatar
Stouts 'n' Scotch
Probably your ignitor going south.
Old Nov 7, 2006 | 07:46 AM
POE's Avatar
POE
maybe your speedo cable isnt in there all the way..
Old Nov 7, 2006 | 07:48 AM
65stang90crx's Avatar
Default Re: (POE)
Is your alternator ok and charging good? While mine was dying I had that problem and my distributor was good.
Old Nov 7, 2006 | 07:50 AM
CRX Toad's Avatar
Default Re: rpm gauge is turning off randomly? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">i agree, probably something in your distributor.
i had the same problem for a while and i just replaced my distributor with another one i got off ebay or something and it went away.</TD></TR></TABLE>
Yup typically what happens....Distributor King for the win. They are also on Ebay.
Old Nov 7, 2006 | 08:18 AM
Tyson's Avatar
Default Re: rpm gauge is turning off randomly? (CRX Toad)
nah, i just bought a used one on ebay for less than a new ignitor alone from the dealer would cost.
although i do recommend distributor king if you want a new one. my friend is completely satisfied with ordering from him.
Old Nov 7, 2006 | 08:47 AM
white ef's Avatar
the same thing happend to me. but it happens only when i turn the turn signal on. when the turn signal isnt on, it works fine. but as soon as i turn on the turn signal it will bounce from 0 rpm's to whatever rpm im currently in.
Old Nov 7, 2006 | 03:30 PM
l1bid0's Avatar
When i was able to drive the car. Sometimes when I turned the signal on it was lag up and then work. Has anyone had it when the check oil/engine seatbelt etc. lights on the gauge cluster will not come on?
Old Nov 7, 2006 | 03:33 PM
SupraRXZ's Avatar
It happend in my car too. Its most likely the speed sensor or something on the tranny...
could be that if your car is driving fine and nothings wrong but your rpm gauge
Old Nov 7, 2006 | 03:37 PM
l1bid0's Avatar
I was able to get it home fine for some reason. But now It wont even start. It's not showing signs of a bad battery or anything. It cranks but wont start. I don't think it's the main relay because I heard that that only happens durring hot weather and it's pretty cold over here. I had my mph sensor out of my tranny after i changed my clutch All that happend was the mph gauge didn't work. Nothing like what's happening now.
Old Nov 7, 2006 | 03:59 PM
white ef's Avatar
cranking and not tuning over is a sign on the timing skipping a tooth or two.
Old Nov 7, 2006 | 04:12 PM
Tyson's Avatar
Default Re: (l1bid0)
open up your distributor. check your rotor. it might have gone bad. if theres red dust, it means the distributor bearing is toast. which will overheat the distributor and melt the rotor.
if not that, then either your ignitor or ignition coil is bad. like i said, i always forget which is which.
test by sticking a screwdriver in one of the spark plug wires and put it near any body part (ground). if you see arcing, then you have ignition and time to look elsewhere.
you can always test your main relay if you can hear the fuel pump prime for 5 seconds when you turn the key to the ON position.
Old Nov 7, 2006 | 04:43 PM
l1bid0's Avatar
I tried putting the screw driver in the wire and the putting the the part above the handle near the ground bolt and nothing happend. So I would need to buy either a ignitor or a ignition coil. I also couldn't hear a fuel pump. But i'm not exactly sure what I'm trying to hear either.
Old Nov 7, 2006 | 04:45 PM
Tyson's Avatar
well you just listen for the hum. but main relay has nothing to do with your ignition. so its your distributor. hopefully others can recommend what part to replace.
open it up and tell us what you see anyway.
just a tip, make sure you use a lot of force downward with a GOOD screwdriver when taking those screws out for the contacts. very easy to strip if youre careless.
Old Nov 8, 2006 | 02:55 PM
l1bid0's Avatar
Default Re: (Tyson)
here are some pics . Is that what I'm supposed to check out?
Old Nov 8, 2006 | 03:09 PM
Tyson's Avatar
wow, you really took it apart!
i was just saying if there was red dust i nthe cap, the bearing is bad. i dont see evidence of that. and the rotor looks fine, although i would judge directly by looking at the rotor screw if its shifted.
but it seems youre fine mechanically. just need to repalce one of the ignitor or ignition coil...
Old Nov 8, 2006 | 05:04 PM
l1bid0's Avatar
was the ignitor or ignition coil the thing i took apart. Like the box type thing i took off?
Built4Battle
Aug 10, 2010 05:01 PM
madriagax619
Aug 22, 2009 05:46 AM
roterx7
Feb 23, 2006 02:57 PM
