ITR Exhaust Fitment on an EK sedan
Old Nov 6, 2006 | 03:00 PM
Moe_Mentum's Avatar
Default ITR Exhaust Fitment on an EK sedan
Hi Guys
I've searched everywhere but I guess no one has asked this before. Can a USDM or JDM ITR axle back exhaust fit properly on a 1999 EK sedan? I basically just need to know if the bend will fit. Also what are the differences between the USDM and JDM ITR exhausts?
I heard the JDM is a 4 door version and thus is longer then the USDM. Will a a full USDM ITR exhaust fit on the EK sedan aswell?
Old Nov 7, 2006 | 05:25 AM
Moe_Mentum's Avatar
Default Re: ITR Exhaust Fitment on an EK sedan (Moe_Mentum)
Anyone?
Old Nov 7, 2006 | 06:05 AM
gottalovethe4door's Avatar
why would the jdm one be specificly for a four door... did honda deprive the good people of japan an integra hatch... i want a jdm integra sedan...
oh, so ne way... do you already have the exhaust... just try to compare pics if you can, but i have seen it done before... if its not an exact fit, then any reputable muffler shop should be able to make it work, good luck
Old Nov 7, 2006 | 06:48 AM
bluelxfodo's Avatar
it should fit really close i put GSR cat back on my EG 4door and it was very close you have to bend the handing arm on the muffler the one on the inside
Old Nov 7, 2006 | 08:46 AM
Moe_Mentum's Avatar
Default Re: ITR Exhaust Fitment on an EK sedan (bluelxfodo)
Not sure... Maybe he might have meant that I should get the 4 Door JDM ITR exhaust since it is longer and will have a better chance and fitting. Not necessarily that all JDM ITR exhausts are 4-door.
But I dunno! hence why I am asking. I actually don't have the muffler yet, but I am in the process of buying one. Just trying to do my research first.
Old Nov 7, 2006 | 08:48 AM
POE's Avatar
POE
buy a muffler and get bigger piping and weld it in.. IMO
Old Nov 7, 2006 | 12:05 PM
Moe_Mentum's Avatar
well I've done that already, 2'5 mandrel bent full exhaust, high flow cat, resonator, etc. The only reason I am getting an ITR muffler is because every muffler I try is way to loud. Right now I have an APexi WSII and its supposed to be one of the quietest but its still deafening.
Old Nov 7, 2006 | 06:08 PM
bluelxfodo's Avatar
the integra coupe exhaust is like and inch or two londer than the civic's. if you take the cat off and get a custom cat/ test pipe then it will fit perfect if you use the 4Door exhaust you will have to do the same the only difference is the rear section which the piping is longer from the flange to the rear section
Old Nov 7, 2006 | 06:23 PM
f20bej1's Avatar
Default Re: (bluelxfodo)
actually i had a itr exhuast on my eg had to get a pipe made so it would fit and we put that on a four door eg it also fit as well. and yes it is nice and quite
Old Nov 8, 2006 | 10:08 AM
bluelxfodo's Avatar
Default Re: (f20b eg)
i agree it is nice and quite
Old Nov 11, 2006 | 02:01 PM
POE's Avatar
POE
so just chop off your old muffler and weld up the rrrrrr.
thejdmkid
Mar 1, 2005 03:51 PM
Reza.dc
Jan 6, 2004 06:11 PM
gorilla nasty
Apr 15, 2003 07:45 PM
citanest
Sep 9, 2001 11:39 AM
brwnrice
Aug 8, 2001 03:54 AM
