Coolant Line To Throtle Body..
Old May 7, 2002 | 05:46 AM
TGUNNER's Avatar
Default Coolant Line To Throtle Body..
Since the weather just got warm here I was going to disonnect and plug the coolant line to the throtle body... Is there a line going in and one out?? Im at work right now and havent looked at it yet... So can someone fill me in on what has to be dissconnected and plugged... thanks in advance...
peace
Old May 7, 2002 | 07:05 AM
Rory Breaker's Avatar
Default Re: Coolant Line To Throtle Body.. (TGUNNER)
2 spigots on the IACV, and one on the bottom of the TB. You are going to plug the one on the bottom of the TB, and T off the one coming out of the engine to the left IACV spigot, with the T going into the other spigot on the IACV.
x........- ..............l...........-
TB---IACV1----IACV2----Engine
Thats about the best I can do...ignore the dots, as I needed to put them there to make it show up right.
Old May 7, 2002 | 07:16 AM
TGUNNER's Avatar
Default Re: Coolant Line To Throtle Body.. (newgsrdriver)
Dont mean to sound dumb.. Where is the IACV located?? Is it behind the throtle body?? Coolant flows through it>???
Thanks Again..
Old May 7, 2002 | 07:25 AM
Its behind the throttle body...behind meaning closer to the firewall. Its held on by 2 12mm bolts, if I remember right.
Old May 7, 2002 | 07:31 AM
TGUNNER's Avatar
AH HA I know what your talking about!!! Thanks man.... Apprecite it....
peaceee
I B BANGGIN
Aug 12, 2007 04:32 PM
done
Oct 14, 2005 12:13 PM
85mm LS VTEC
Apr 11, 2005 11:06 AM
igo4bmx
Apr 8, 2004 07:25 PM
ARACER25
Oct 13, 2002 10:41 AM
