Ignition timing.
Old Nov 6, 2006 | 02:36 PM
h_turbo's Avatar
Default Ignition timing.
As some of you may know MBT (mean best torque) is produce at 15 degrees after top dead center, so my question is: in order to achieve MBT where should the spark start at idle? How many degrees after or before TDC? I hope i'm making my self clear. Thanks.
Old Nov 6, 2006 | 02:43 PM
Relic1's Avatar
Unless I'm mistaken... MBT is dependant on cylinder size, fuel mixture, piston speed, spark plug location, and a few hundred other things.
putting a certain 15* value on it requires more of an explination than what you have given.
Old Nov 6, 2006 | 02:47 PM
h_turbo's Avatar
Ok, stock B series and like I said IDLE, I think that tells you about piston speed. Thanks.
Old Nov 6, 2006 | 03:08 PM
Relic1's Avatar
honda uses 16* for a reason.
BTW, it's before top dead center.
Old Nov 6, 2006 | 03:16 PM
h_turbo's Avatar
Thank you.
Old Nov 6, 2006 | 04:31 PM
Relic1's Avatar
did that answer your question, sorry I'm not trying to be an a-hole with the comments above.
Simply confused by your question.
Old Nov 6, 2006 | 05:01 PM
Scott_Tucker's Avatar
Default Re: Ignition timing. (h_turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h_turbo &raquo;</TD></TR><TR><TD CLASS="quote">As some of you may know MBT (mean best torque) is produce at 15 degrees after top dead center, so my question is: in order to achieve MBT where should the spark start at idle? How many degrees after or before TDC? I hope i'm making my self clear. Thanks.</TD></TR></TABLE>
I think you mean MBT is achieved when peak cylinder pressure occurs 15 degrees ATDC and you are asking how advanced the spark needs to be to achieve this at idle. ????
Why do you care what it is at idle? Do you drive your car there? The timing required to achieve MBT is going to be different depending on engine and it's design factors.
Old Nov 7, 2006 | 06:47 AM
h_turbo's Avatar
Default Re: (Relic1)
Yes, that answered my question.
Old Nov 7, 2006 | 06:49 AM
h_turbo's Avatar
Default Re: Ignition timing. (Scott_Tucker)
Ok, did I said I'm driving my car at idle?? Of course not!!! My question is already answered.
VTEC_Du_Ma_Mai
Mar 5, 2012 11:22 PM
iCollectStraws
Jan 8, 2009 01:16 PM
DonF
32
Jan 8, 2007 11:55 AM
toooslow
Sep 29, 2005 07:11 AM
