Suspension & Brakes Theory, alignment, spring rates....
Rough sound when under normal driving, half shaft?
Old Nov 6, 2006 | 02:24 PM
OMG THE GOGGLES's Avatar
Default Rough sound when under normal driving, half shaft?
Hello, I have a problem, when I am driving in a straight line, or turning right, the driver side front end of my car makes a noise that almost sounds like a toned down version of driving on snow, its not a squeal or click, but more or less sounds like some sort of unlubed bearing or something, instantly when I turn left, wheter a little or all the way the sound goes away. Almost sounds like driving on snow a little bit, on normal concrete. I am curious to find out what causes this and if I can simply lubricate the part that is spinning rather than replacing it. I never thought much of it until more people started noticing this recently (I have bad hearing). Thanks guys.
Old Nov 6, 2006 | 04:53 PM
Default Re: Rough sound when under normal driving, half shaft? (gasp0matikz)
Wheel bearing? Axle? Half Shaft?
Old Nov 7, 2006 | 04:21 AM
bbbbb
Old Nov 7, 2006 | 02:37 PM
brumpppp
Old Nov 8, 2006 | 03:16 PM
snowboardgeek1's Avatar
I had that problem. Wheel bearings in the front needed to be replaced.
Old Nov 8, 2006 | 03:22 PM
dvp's Avatar
dvp
Default Re: (snowboardgeek1)
The halfshaft usually lasts the life of the car. Sounds like the axel or a really bad wheel bearing.
Old Nov 9, 2006 | 01:57 PM
Default Re: (dvp)
I think I am going to replace both, usually I stick with oem, but is it a bad idea to go aftermarket. Im willing to spend the 100 bucks on oem for both sides if it is worth the differnce in quality.
xtreme-customz
Nov 29, 2010 05:26 PM
jkalex05
Nov 23, 2009 06:52 PM
Bobbyt5408
Suspension & Brakes
Oct 28, 2008 07:58 AM
wdyno
May 14, 2002 06:46 PM
Rain_man
Jun 21, 2001 10:21 PM
