REAR DISC QUESTION keeping the VX fronts with teg rears ***SEARCHED*** GURU NEEDED
Old Nov 6, 2006 | 01:16 PM
punkracer's Avatar
Default REAR DISC QUESTION keeping the VX fronts with teg rears ***SEARCHED*** GURU NEEDED
hey guys whats up...got a quick brake question ...i have a 95 vx and was wondering about my brake setup. i still have drums in the rear and will be swaping out for 94 teg rs non abs rear disc.
the reason for not doing the front teg brakes is i still wanta rock my vx wheels...9lbs is nice.. and with good tire they should rock for autox
i have a 94 rs to get the parts off and then ill be putting the rear drums on the teg so i can sell it...that should be fun the only teg with drum rear brakes...lol
<U> QUESTIONS:</U>
will i benifit from a "4040" proportion valve?
will i benifit from a RS master cylider 15/16?
is there a big diffrence in the 15/16" and the 1" master cyliders?
how do i blead a master cylinder without the bleader kit? (lil plastic fittings and hose) can i just buy the kit?
i plan on autox this next season and want a nice setup with some good rotors and brake lines and pads soo i thoguht i would get the rear conversion done then upgrade the system in the spring...
Old Nov 6, 2006 | 01:45 PM
vietnameeh's Avatar
upgrading to rear discs put you in a different class
Old Nov 6, 2006 | 01:58 PM
punkracer's Avatar
thats fine...just need to know brake info not autox info
Old Nov 7, 2006 | 08:11 AM
punkracer's Avatar
lkjndlknasd
bump
Old Nov 8, 2006 | 08:55 AM
kaiba's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietnameeh &raquo;</TD></TR><TR><TD CLASS="quote">upgrading to rear discs put you in a different class</TD></TR></TABLE>
What will that put u in???
Old Nov 8, 2006 | 12:08 PM
vietnameeh's Avatar
i believe SM...
Mr_Si-R
46
Nov 4, 2005 06:05 PM
Weapon_R
11
Jun 4, 2005 09:15 AM
STN_Pat
Feb 24, 2004 05:29 AM
J.P.
Feb 14, 2003 10:25 PM
STK B16
29
Feb 2, 2003 01:24 PM
