Want to Buy Want to Trade/Want to Buy
WTB: LS longblock b18b for turbo build
Old Nov 6, 2006 | 12:57 PM
92civichatch1's Avatar
Default WTB: LS longblock b18b for turbo build
title states it all im in NJ need a long block to start buildin in the winter for turbo in the spring
Old Nov 6, 2006 | 03:08 PM
redex04's Avatar
Default Re: WTB: LS longblock b18b for turbo build (92civichatch1)
have a b18b block with everything removed but the internals and oil pan, still have all the other parts that were removed, located in pa, 92k on motor, let me know if you want to work something out
Old Nov 6, 2006 | 06:45 PM
Default Re: WTB: LS longblock b18b for turbo build (redex04)
pmed anyone else
Old Nov 6, 2006 | 07:09 PM
redex04's Avatar
pm'd back
Old Nov 7, 2006 | 10:07 PM
bump
Old Nov 8, 2006 | 11:22 AM
gotboostedvr6's Avatar
i have a ls w/ cracked sleeve ill sell cheap has shot peaned rods and arp rod bolts new acl bearings
Old Nov 9, 2006 | 10:18 PM
lthao61's Avatar
ill sell you my bare block for a 130 shipped 119k miles
lmk
Old Nov 10, 2006 | 08:09 AM
the g2 teg's Avatar
pmd
Old Nov 11, 2006 | 04:51 AM
HTLuver's Avatar
I got one with 85,000 miles on it. I just replaced the head gasket. $400
IM me if interested.
Old Nov 14, 2006 | 07:26 AM
Mr.Chow's Avatar
I have a built LS motor for sale. it is built for turbo. less than 30,000 miles since rebuild.... all new performance parts.... cost me over 3 grand to build. my car was totaled in the rear so i have the engine just sitting here. take a look at the thread, screw building a motor from the ground up when mine is already built!!!!!!! balanced and blueprinted! all new valves, gaskets, rods, pistons, cams, cam gears, titanium valve springs and retainers! knifedged crank! acl bearings! venom injectors!!!!!!! BUY FOR CHEAP! I NEED TO GET RID OF THIS THING!
http://hondamarketplace.com/zerothread?id=1693821
Old Nov 16, 2006 | 06:42 AM
sik_sol's Avatar
B A N N E D
hey i've got a b18b longblock and y80 LS tranny out of a 94 teg. the blocks been rehoned, hot tanked, so its all set to be rebuilt. new acl bearings, oem rings, GSR crank, rods, and USDM ITR pistons for mild bump in compression, ie 10.4:1. (about the same as b16a set up). umm, stock injectors, fuel rail, intake manifold, wiring harness, p75 5 speed ecu, shift linkage, everything needed to swap including mounts and drivers side axle. well let me know if you're interested, you can drop me an email to carbonfiberkeyboard@yahoo.com. thanks, lates
Old Nov 16, 2006 | 01:24 PM
B18T3T4's Avatar
I have a B18b head. Crower springs, crower retainers. crower valves and crower 404 cams. Also VictorXintake manifold, LMK if your interested
Old Nov 20, 2006 | 10:34 AM
SOHCD16y8's Avatar
I have a great set of pistons and rods for that block, check my sig. Pmd also.
Old Nov 21, 2006 | 07:30 PM
ValleySyder's Avatar
Default Re: (SOHCD16y8)
i have a gsr longblock .. needs rebuild... willing to sell longblock for 850 and i can met u halfway ..
Old Nov 22, 2006 | 09:48 AM
Loserkidwac's Avatar
Default Re: (ValleySyder)
I have a dissasembled B18b and B18a if you are looking to build it you can put whatever you want back in it, not looking to much located in SE PA, pm me if you are interested...matt
bryan.a.wolfe
Dec 15, 2008 08:56 AM
Rhymenoceros
Feb 7, 2008 06:00 AM
94b18hatch
Oct 27, 2007 09:42 AM
